KZ 200 overbore
- Spectre1982
KZ 200 overbore
15 Jul 2013 21:34
I just acquired a barn find KZ 200. Compression is about 90. Runs terrible and smokes like a chimney. I took the top end apart and measured the barrel. The cylinder is worn past the service limit. Does anyone know where to find an oversize piston and rings? It's a 66mm standard bore. I think it may be the same as the 900 piston. Not sure on that.
Any help would be appreciated. Thanks.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
Re: KZ 200 overbore
15 Jul 2013 22:19 - 15 Jul 2013 22:22
Here's a new old stock (NOS) one that's .040" oversize for $30:
www.nwvintagecycleparts.com/search-resul...rch.x=10&search.y=15
The .040 over rings are still an "Active" part so any dealer can order them.
Partzilla lists the rings at $46.40.
find.partzilla.com/?r=t&q=13024-5005&x=5&y=9
Double check the part numbers, but I think I show the right ones. Ed
Attachment 00000_2013-07-15-3.jpg not found
Last edit: 15 Jul 2013 22:22 by 650ed.
The following user(s) said Thank You: Spectre1982
- Nebr_Rex
Re: KZ 200 overbore
15 Jul 2013 23:12
66mm is the standard bore for the 900 like you said and they have a 17mm wrist pin.
Also the 750/4 is the same bore but with a 15 mm wrist pin.
Only thing to measure is the pin height to see if one of them matches.
900s usually get taken out to 70mm,1015 CC right away.
750s big bore is 69 mm,810cc and the 440 is the same pin height at a stock 67.5mm.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- car5car
- Banned
Re: KZ 200 overbore
15 Jul 2013 23:38 - 16 Jul 2013 12:27
$600 retail kbb book value.
Doesn't make sense to repair unless you do it for fun.
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 16 Jul 2013 12:27 by car5car.
- Nebr_Rex
Re: KZ 200 overbore
16 Jul 2013 00:20
Who are you and what do you knowof this bike?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Motor Head
Re: KZ 200 overbore
16 Jul 2013 00:23
No eBay APP ID and/or Cert ID defined in Kunena configurationAny one know if this would bolt on? Or do the cases need bored, and the pin dia different etc?
- Spectre1982
Re: KZ 200 overbore
16 Jul 2013 09:57
Thanks for the responses. That 250 head looks identical to the one that came off but I'm not 100% certain if everything is the same. That is definitely a route to consider. Gonna review my options and order parts tonight. Should have it back in service by this time next week.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- Motor Head
Re: KZ 200 overbore
16 Jul 2013 10:05
There are some threads on it, but I don't know if its a direct swap. In this thread it still looks like a question. So do some research into the stroke, see if they share the same crank and con rod. kawasaki.com will have that info, in the parts diagrams click on the yellow question mark once you locate the part #. It all under "Owner Info"
www.kzrider.com/forum/2-engine/99476-how...odify-kz200-to-kz250
- car5car
- Banned
Re: KZ 200 overbore
16 Jul 2013 14:20 - 16 Jul 2013 14:24I usually use bikebandit.comMotor Head wrote: There are some threads on it, but I don't know if its a direct swap. In this thread it still looks like a question. So do some research into the stroke, see if they share the same crank and con rod. kawasaki.com will have that info, in the parts diagrams click on the yellow question mark once you locate the part #. It all under "Owner Info"
How many gaskets will you need? What did I miss?
head gasket
cylinder gasket
valve seals
Last edit: 16 Jul 2013 14:24 by car5car.
- Spectre1982
Re: KZ 200 overbore
16 Jul 2013 14:29car5car wrote: $600 retail kbb book value.
With all due respect, I asked for information on pistons and rings, not an opinion on whether it was worth the rebuild or not. Putting another KZ back on the road is worth the $150 in parts to me. A beginner friend of mine offered to buy it to get started with motorcycling. Fun is what it's all about.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- Spectre1982
Re: KZ 200 overbore
16 Jul 2013 14:36
Thanks for the replies everyone. I got everything ordered and it should all be here by this weekend. I'll let you know if I run into any problems.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- Motor Head
Re: KZ 200 overbore
16 Jul 2013 23:46
Which direction did you go? Just curious. Wondering if you went up to the "Big Block" 250.
