engine cleaning
- kamakazie1000
engine cleaning
12 Jul 2013 12:25
Greetings Member Of The Kzrider Community!
So I Got My Cases Split Yesterday And Am Going To Start The Cleaning Process. I'm Going To Start With The Cases Themselve, Then The Internals. What Does Everyon Use For Cleaning? I Was Planning On Soaking Them In Mineral Spirits Followed By A Vigorous Attack By Wire Brush And Elbow Grease, Howeve I Thought I Would Defer To The Expertis Of The Kzrider Gurus BeforeI Start.
Any Advice, Comments, Concerns Would Be Greatly Appreciated.
Thanks,
John.
Thanks,
John.
Terminal lance corporal of Marines, putting the GRUNT in disgruntled
kz1000 cafe project
kz1000 cafe project
- car5car
- Banned
Re: engine cleaning
14 Jul 2013 00:56
Stop using capital letters.
96 Yamaha Royal Star
82 Yamaha Virago 920
- steell
Re: engine cleaning
14 Jul 2013 01:00 - 14 Jul 2013 01:00car5car wrote: Stop using capital letters.
Already had this discussion, he's using a mobile browser that does that automatically.
It do make it difficult to read though, it's like a whole crapload of single word sentences :laugh:
Last edit: 14 Jul 2013 01:00 by steell.
- Old Man Rock
Re: engine cleaning
14 Jul 2013 08:16
Attachment SimpleGreen.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kamakazie1000
Re: engine cleaning
14 Jul 2013 15:10
Thanks old man rock! I'll be picking up some simple green here promptly. Could you maybe elaborate a bit on the cleaning polishing procedures you used? I was going to have everything blasted and painted but if i can get results like that, i'll just do it myself!
regards,
J.H.C
regards,
J.H.C
kz1000 cafe project
kz1000 cafe project
- Powerstroke_fan
Re: engine cleaning
14 Jul 2013 16:48
I have a harbor freight sand blasting cabinet so i sand blasted mine.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Glen4747
Re: engine cleaning
23 Jul 2013 18:48
kzrider.com/forum/6-paint-a-bodywork/587...lished-engine#588171
There are some explanations on how to polish with the wire wheels and simple green in that topic:
1976 KZ900 A4
- K.D. HART
Re: engine cleaning
23 Jul 2013 23:27Glen4747 wrote: kzrider.com/forum/6-paint-a-bodywork/587...lished-engine#588171
I'll be damned, and I've been rubbing cases with sandpaper till my fingertips became raw.
Wish I'd seen this sooner
I need to find those brushes. I haven't seen them in any of the stores here and I've been in the one's OMR listed. I'm sure I can find them on line though.
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
- Glen4747
Re: engine cleaning
24 Jul 2013 10:37
I had to buy mine from amazon, couldn't find them in any stores.
www.amazon.com/gp/aw/d/B001F527SW/ref=mp...72987&sr=8-8&pi=SL75
1976 KZ900 A4
- Glen4747
Re: engine cleaning
24 Jul 2013 21:46
Does anyone know if these nylon wire brushes are safe on all metal, such as the exhaust pipes? I just tried them out with some simple green and they really do work great. The fine brush easily removed bluing from the pipes that has been on there since I got the bike. And it takes surface rust off like it's just dirt. Anyway, just wanted to make sure they were safe for the exhaust pipes. Thanks.
1976 KZ900 A4
Re: engine cleaning
25 Jul 2013 10:00 - 25 Jul 2013 10:00
Tampico brushes are another option - they're made from natural fibers. I think they're often used for cleaning spoked wheels but are also good for engines. The long thin brushes can reach between the fins.
Last edit: 25 Jul 2013 10:00 by martin_csr.
- K.D. HART
Re: engine cleaning
25 Jul 2013 12:24martin_csr wrote: Tampico brushes are another option - they're made from natural fibers. I think they're often used for cleaning spoked wheels but are also good for engines. The long thin brushes can reach between the fins.
Do you have a link that I could order these from?
Never heard of them before, but need to clean in between my fins
