Scoring on cylinder
  • steell
  • steell's Avatar
Re: Scoring on cylinder
11 Jul 2013 12:37
#595991
geohaydook1 wrote: Steell,
So I should just hone the cylinder, button it back up, and save up for an 810 kit?
That's what I'd do, otherwise the bike just sits there all summer while you struggle to save the money to buy all the parts.
Just ride it till winter, then tear it down.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
11 Jul 2013 16:14
#596028
a fresh hone,
a new set of rings(on that piston only)that have the proper ring gap.
should go a long way towards stopping the smoking.
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
14 Jul 2013 01:00
#596368
Hone cylinder for 5-sec, put it back together, run engine, check compression and be happy.
I bought a Lincoln, engine was completely filled by water. Water was there a few weeks, cylinders were rusty.
Honed, installed new rings, perfect compression!
96 Yamaha Royal Star
82 Yamaha Virago 920
  • geohaydook1
  • geohaydook1's Avatar Topic Author
14 Jul 2013 03:47
#596382
Thank for the info and encouragement. Off to the machine
Shop Monday. Now all I have to do is build some carbs, sort
Out the electrics....... etc To be continued........
1980 KZ750e
1981 KZ650 csr (fate undecided)
  • geohaydook1
18 Aug 2013 20:25 - 18 Aug 2013 20:59
#602049
Okay,
The original cylinders were to badly damaged to be saved, so I'm using a spare set that came with the bike. They just came back from the machine shop after a light hone to clean them up, so now I've got everything I need ( I hope) to put the engine back together. I have three questions.
1. Should I do anything to the piston to remove the scuffing on the front face? I can't see it, but I can feel it with a fingernail.
2. How do I set the ring-end gap?
3. Can I get the cylinders over the pistons without a ring compressor? I really don't want to buy a tool that I'm only going to use (hopefully) once.
Any advice is greatly appreciated.
1980 KZ750e
Last edit: 18 Aug 2013 20:59 by geohaydook1. Reason: notification
  • 531blackbanshee
  • Vendor
  • Vendor
19 Aug 2013 11:39
#602113
1- if the scuffing offends you lightly buff it off with scotchbrite or fine (like 1000 grit) emery cloth
2- you set the ring end gap by putting a ring in the cylinder and using a piston to push it down enough to make sure it is square in the bore.then using feeler gauges you measure the end gap.
.012-018 thsnths(.31mm-.46mm)is the target for your end gap.
i clamp a file in the vise and hold the rings in my hand and pinch both ends together on the file and lightly file back and forth then check until i have my target number.
3- if you are patient and careful you can get the cylinders back on without a ring compressor.
hth,
The following user(s) said Thank You: geohaydook1
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
20 Aug 2013 10:42
#602294
forget about 1,2 or research internet/read manual. I don't repair engines w/o service manual.
Buy ring tool, then return it or keep it. you don't want to break/bend springs.
20 Aug 2013 22:36
#602381
geohaydook1 wrote: ... Can I get the cylinders over the pistons without a ring compressor? I really don't want to buy a tool that I'm only going to use (hopefully) once....
Some diy options --
www.kzrider.com/forum/21-tools/532979-gh...g-compressors#532979
www.kzrider.com/forum/21-tools/360628-sm...ng-compressor#361010
Good Fortune! :)
  • geohaydook1
21 Aug 2013 15:27
#602477
That's pretty smart! I don't have an old license plate, so I may have to use some "energy drink" containers ;) Think that will work?
1980 KZ750e
  • geohaydook1
03 Sep 2013 12:09
#604597
:pinch: I took the #3 piston off to buff out the scratches and install the new rings. When I installed the piston back onto the connecting rod ( using a new clip), I noticed that it wasn't pivoting as freely as the others and felt a little stiff. I had also put the wrist pin in the freezer to ease installation.What gives?
1980 KZ750e
03 Sep 2013 15:02
#604632
Could try reversing the wrist pin to see if it makes a difference.
Good Fortune! :)
  • geohaydook1
04 Sep 2013 11:53
#604777
Thanks, I'll try that first chance I get.
1980 KZ750e
