Kawasaki GT750 cafe racer build
- daventry
03 Jul 2013 08:15
I recently purchased a kawasaki GT750 as a project bike. I've done some body work and replaced the exhaust which resembled a block of Swiss cheese when I picked it up.
Now it's time to focus on registration as a minimum. I haven't ridden it yet!
I've started it up, but it won't idle without stalling. I need to keep the throttle on slightly to prevent stall. I've added injector cleaner to the petrol which seemed to help.
From what I understand, there's an issue with the carbies. Any suggestions?
- Del_Herring
Re: Kawasaki GT750 cafe racer build
03 Jul 2013 11:05
If she otherwise idles fine, your idle speed adjustment may just be off (all it really does is hold open the throttle a little). Not sure about the GT750, but on most bikes, it's just a little knob/screw that can be turned by hand in the middle of the carb rack. If turning that up a little gets it to idle smoothly, I'd call it good on that front. If it keeps going but is still rough, you might need to look into other stuff.
Fuel level, and a general need for cleaning are pretty common in carbs. The boots tend to get old and cracked, but that causes lean symptoms, which you didn't mention, so you might be fine there.
Videos can be really helpful for diagnosing if you have a way to grab one. A lot of guys here have enough experience to help point you in the right direction there, but it can be hard to describe what we'd be looking for if you don't already know what we're looking for.
1983 KZ750-N2 Spectre
- slayer61
- KZR FLAG RELAY CARRIER #62
03 Jul 2013 17:11daventry wrote: I recently purchased a kawasaki GT750 as a project bike. I've done the exhaust which resembled a block of Swiss cheese when I picked it up.
quote]
Do the Swiss know that you have their exhaust? :woohoo: :S They've been looking for it!
- steell
03 Jul 2013 17:40
Is the GT750 a shaft drive bike?
