Curious starting issue
  • gdc6661
  • gdc6661's Avatar Topic Author
01 Jul 2013 20:51 - 01 Jul 2013 20:54
#594630
Hi all.
I have a starting issue that I feel sure someone on this site will have an answer to.
I have a KZ750 ltd, 1982 that starts and runs fine but it will take longer to start depending on how long it has stood. For example: If I park the bike after a ride and go back to it after 24 hours, it will start instantly. If I go back after a 48 hour break it will take about 3 seconds on the button before starting. After 72 hours I am looking at 10 seconds on the button and a full week will result in about 30 seconds before starting. Good job my battery is good! Could the fuel be evaporating off while standing? I have no carb leaks.
Once started it runs absolutely fine but is never keen on holding a steady throttle. She seems to prefer to be either on or off throttle. Not a major problem though.
Anyone got any idea what might be causing this strange starting issue?
Thanks.
Gary.
PS. Forgot to mention that a friend also has a 750 ltd (1981) with a very similar problem.
1982 KZ 750 LTD Bog standard.
Last edit: 01 Jul 2013 20:54 by gdc6661. Reason: Missing text
  • JR
  • JR's Avatar
Re: Curious starting issue
01 Jul 2013 21:10
#594631
Try putting the petcock on Prime for a few seconds if the bike has sat for a day or more. If you have a clear fuel filter you will probably notice it filling up. If I leave my 750 for a few days or a week it will take maybe 5 seconds to start but I put that down to the battery being about 3 years old and while the dash will say 12 V I believe it does lose power and the motor doe not seem to spin as fast if bike sitting for a few days or a week.
30 seconds is not right. Probably evaporation
  • gdc6661
01 Jul 2013 21:23
#594636
Thanks for that JR.
I tried priming for a minute or so and that seemed to reduce the starting time quite a lot although I didn't watch the filter filling up. I will try that again tomorrow as it has been standing for over a week. Will let you know how it goes.
I will also check the fuel level in the bowls before priming and starting.
Thanks again.
Gary.
  • gdc6661
03 Jul 2013 18:05
#594920
Hi JR. Tried priming again like you said and seemed to work this time. Started after just 2 or 3 seconds and has stood for over a week. What do you think would cause so much evaporation in just a week of standing? Thanks again.
Gary.
03 Jul 2013 18:39
#594933
The need to prime the carbs is normal. Keep in mind that there may be just a small amount of evaporation; just enough to lower the fuel level in the bowls below that which is best for starting the engine. I'm sure the bowls are not actually empty after a week. Ed
  • gdc6661
03 Jul 2013 18:44
#594934
Thanks for that Ed.
That makes sense.
So the rule of thumb would be to use prime any time it has stood for more than a day or 2.
Thanks again.
Gary.
