Clutch Replacemnent Due?
  • nivlac
  • nivlac's Avatar Topic Author
30 Jun 2013 15:04
#594481
Trying to break the bolt on the alternator rotor. My engine turns over. Holding the brake the engine still turns. Is my clutch shot? It seems to shift well w/o slipping. Although I'm not inclined to do any hole shots, just a little hammer on through the gears and like I say it doesn't seem to be slipping. I think it is adjusted up to par. Where should I look, or do I not have an option besides replacement?
1983 kz1100
1979 cb650
  • gengomerpyle
  • gengomerpyle's Avatar
Re: Clutch Replacemnent Due?
30 Jun 2013 15:06
#594482
how would holding the brake keep the engine from turning over?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
30 Jun 2013 15:14
#594483
gengomerpyle wrote: how would holding the brake keep the engine from turning over?
If the transmission is in gear the engine will try to turn the drive chain. Holding the rear brake or blocking the wheel from turning should prevent the engine from turning over. Ed
01 Jul 2013 00:37
#594547
Has the counter-shaft sprocket come loose?
Good Fortune! :)
  • nivlac
01 Jul 2013 06:52
#594565
If the counter shaft is the gear assembly between the starter and the larger gear behind the rotor, then yes. This has been the original problem it kept working its way from the position that it should be in and would ultimately not mesh correctly when the starter was engaged. I was told that my starter clutch was in question. It seemed like such an easy fix and relatively cheap I thought why not? But yes if that is the counter shaft sprocket it is currently off the assembly.
1983 kz1100
1979 cb650
