- Thank you received: 13
Engine crack. Crank case?
- DobbinsCMA
24 Jun 2013 20:38 #593770
by DobbinsCMA
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
Engine crack. Crank case? was created by DobbinsCMA
Bought this bike a month ago. Rides fine. Noticed this crack. I did not drop it but there seems to be some evidence that the last guy did lay out. Whats going on with this?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- roy-b-boy-b
- Thank you received: 103
24 Jun 2013 21:45 #593785
by roy-b-boy-b
Replied by roy-b-boy-b on topic Engine crack. Crank case?
Welcome , That is not critical but needs replacing. Moisture could get in and cause problems. You should post these pictures in Wanted . I am sure there is a member that has that piece.
- P21
- Thank you received: 34
24 Jun 2013 21:50 #593788
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Engine crack. Crank case?
there no oil behind that so your good to go
maybe run it to the riding mower in garage...........lol
- Thank you received: 2098
24 Jun 2013 22:32 #593798
by Patton
Replied by Patton on topic Engine crack. Crank case?
Thinking maybe the bike went down, with the outer points cover absorbing most of the damage (beyond repair) -- but with inner cover only being cracked -- and the outer points cover having been replaced.
