KZ250 Tach cable removal
- MaxFly
19 Jun 2013 23:12 #593158
by MaxFly
KZ250 Tach cable removal was created by MaxFly
Hi List;
I have recently acquired a 1982 KZ250. It's in mint original condition with only 17000km (10500 miles)on it. The bike runes great. My problem is that I have a small oil leak where the tach cable enters the head. I tried to unscrew the tach cable like it says in the service manual but it will not budge. It will nor screw out or in. Am I missing something? The manual states to just unscrew it with a pair of pliers.
Help!!
82 KZ LTD250 belt drive
Help!!
- Thank you received: 2829
20 Jun 2013 00:11 #593161
by 650ed
Replied by 650ed on topic KZ250 Tach cable removal
It should just unscrew; be sure to turn it counter-clockwise. The seal should be replaced to stop the leak, and the parts are still available. If you cannot get it to unscrew soak it for a couple days with Kroil penetrating oil; that should break the bond. Ed
- MDawnz1
- Thank you received: 27
20 Jun 2013 02:09 #593170
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic KZ250 Tach cable removal
Sounds like a cool little bike.
How about just ordering the seals and a new cable for it?
I mean that sucker has been on for more the 30 years.
1974 Z1a, still 903
- MaxFly
24 Jun 2013 13:19 #593721
by MaxFly
Replied by MaxFly on topic KZ250 Tach cable removal
Thanks - I figured so. I'll start soaking it in Deep Creep and see if it lats go.
- MaxFly
24 Jun 2013 13:22 #593722
by MaxFly
snip>
snip>
That's the plan if I can just get the old one out.....
snip>
- MaxFly
08 Jul 2013 12:23 #595537
by MaxFly
Update - Well I still can't get the tach cable to budge. I've been giving it a soak in Deep Creep (SeaFoam) every couple of days but I can't get it to move. The good news though is that the leak has stopped. I wonder if the Deep Creep caused the seals to swell enough to stop the leak. I'll keep at it because I'd really like to replace the old cable anyway.
