What is a good compression for a KZ 1000?
  • anotherZ
  • anotherZ's Avatar Topic Author
19 Jun 2013 14:19
#593074
I measured 110-120 psi across the board on all cylinders.
I know that the volume inside the hose of the vacuum gauge causes a bit of an error. I calculated the hose volume as 5cc, and applying some fuzzy math I calculate the resulting error of the compression measurement to be 15% because of the hose volume.
That would put my measurements in the 125-140 psi range, is that acceptable? Engine was cold, throttle closed. Thanks.
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
Re: What is a good compression for a KZ 1000?
19 Jun 2013 17:46
#593107
Standard is 128~156 psi; service limit 100 psi.
Some large four Kaw engines perform surprisingly well with less than 100 psi.
Good Fortune! :)
  • anotherZ
19 Jun 2013 17:53
#593110
Thanks. So not that bad then!
79 KZ 1000 LTD
Smaller tank
  • P21
  • P21's Avatar
19 Jun 2013 17:59
#593113
throttle closed
throttle open and them numbers go up!
Kawasaki KZ 1000 Police (2002) P21
  • anotherZ
19 Jun 2013 18:18
#593115
Will do and report back. Thx!
79 KZ 1000 LTD
Smaller tank
  • anotherZ
19 Jun 2013 19:15
#593122
Tested again at WOT, now I am between 135 and 150, not bad at all!
79 KZ 1000 LTD
Smaller tank
