- Thank you received: 5
Starter gear slipping out of place
- nivlac
17 Jun 2013 20:14 #592768
by nivlac
1983 kz1100
1979 cb650
Starter gear slipping out of place was created by nivlac
The starter gear on my 83 kz1100 has slipped out of place for the second time in the last couple of weeks. I'm wondering if there is some kind of shem that would take up the space between the end of the pin/ shaft that runs through the middle of the gear assembly and the recessed pocket in the cover that holds the pin in place. I'm not seeing anything like a spacer or shem in the schematics. Any ideas?
1983 kz1100
1979 cb650
- Motor Head
- Thank you received: 391
17 Jun 2013 21:43 #592788
by Motor Head
Replied by Motor Head on topic Starter gear slipping out of place
Best to post some pictures of your issue. That may clear up whats the problem.
- daveo
- Thank you received: 655
17 Jun 2013 22:35 #592801
by daveo
1982 KZ1100-A2
Replied by daveo on topic Starter gear slipping out of place
Unless the casting is broken, I can't imagine how the pin could move and allow the gear to come out of alignment. If the stator cover, get another. :huh: If the engine case, good luck.
1982 KZ1100-A2
- crh
- Banned
- Thank you received: 20
18 Jun 2013 08:14 - 18 Jun 2013 08:19 #592844
by crh
Replied by crh on topic Starter gear slipping out of place
Sounds like you're missing a thrust washer on the starter gear shaft and it's allowing the gear to move outboard away from contact with the starter clutch gear on the crank.
Are you certain the rotor is not coming loose and allowing the starter clutch gear to walk instead?
Last edit: 18 Jun 2013 08:19 by crh.
- nivlac
18 Jun 2013 11:16 #592872
by nivlac
The difference in measurement in the gear pin and the retaining pocket in the cover is 55 thousandths.
1983 kz1100
1979 cb650
Replied by nivlac on topic Starter gear slipping out of place
1983 kz1100
1979 cb650
- daveo
18 Jun 2013 21:16 #592951
by daveo
1982 KZ1100-A2
Is all good behind the starter gear?
1982 KZ1100-A2
- Motor Head
18 Jun 2013 22:02 #592966
by Motor Head
Are you sure it isn't a starter clutch issue? This is more common. There are 3 Allen head bolts where the starter clutch hub bolts to the Rotor that back out. They need a few drops of Loctite and re-torquing. But the starter clutch springs and rollers are a common issue.
- nivlac
19 Jun 2013 07:21 #593019
by nivlac
1983 kz1100
1979 cb650
Thanks, that where I'm going next.I'm thinking you're right. I'm not even going to check, but instead simply replace with a fresh rebuild kit. They are pretty inexpensive and I'd like to eliminate problems and ride.
1983 kz1100
1979 cb650
- nivlac
19 Jun 2013 07:26 #593020
by nivlac
1983 kz1100
1979 cb650
I replaced the starter with a new one last season, which is all that I have done down below in that area.daveo wrote: Is all good behind the starter gear?
1983 kz1100
1979 cb650
