Stock setting for carb idle screw
  • SATSFYD
  • SATSFYD's Avatar Topic Author
17 Jun 2013 14:09 - 17 Jun 2013 16:09
#592718
Hey what is the stock carb idle screw setting for a 1980 KZ750 (4 cyl) LTD? How many turns from set? That would be the fuel mixture screw that is on the top of the carb that comes stock with a plug over it.
Last edit: 17 Jun 2013 16:09 by SATSFYD.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Stock setting for carb idle screw
17 Jun 2013 16:46
#592732
IIRC the stock setting was 2 turns out from very lightly seated. I have attached what I think is the correct stock info for the Kehien CV34 carbs that were used on that model.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: SATSFYD
