weld crank
  • aviliora
  • aviliora's Avatar Topic Author
weld crank
15 Jun 2013 03:32
#592381
Hi,
Is there any way to find if the crankshaft is weld without splitting the cases?
kz100j
Tnx
  • gearheadmm
  • gearheadmm's Avatar
  • MUCH MORE BOOST..........I mean BRAVO
Re: weld crank
15 Jun 2013 04:04
#592384
Drop the pan.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
  • zed1015
  • zed1015's Avatar
Re: weld crank
15 Jun 2013 04:13
#592386
The easiest way especially if the engine is still in the bike is to remove the exhaust and sump. This involves the least amount of disassembly and will give you the opportunity to check that the oil pump gauze is clear at the same time as well as the condition of the gearbox.
