Kz900 sitting for 10 years
- SeattleKZ
15 Jun 2013 01:44
So the bike is clean and will start but I don't want to run it long distance until I've cleared everything up.
I've already cleaned the carbs, tank and put in new file lines with filters.
It's got some wiring issues that I'm sorting out and should have that done in a out a 1-2 weeks.
Right now it's showing about 100 psi in each cylinder. I know that's low but I'm hoping its just because it was sitting for so long. I changed the oil. I plan to check the valves after the electrical is sorted.
My question is...
If the rings are stuck from sitting is there way to loosen things up without opening up the top end?
My question is...
- roy-b-boy-b
Re: Kz900 sitting for 10 years
15 Jun 2013 08:38
I have started the engine with the air filter off and sprayed a whole can of wd 40 in the ports while the bike is running.
I would put some light oil in the cylinders while the bike is sitting. I think you will be alright with that pressure. It more than likely will come up after start up.
- SeattleKZ
15 Jun 2013 09:54
The wd40 thing is a good idea. What kind of oil is good to pit in the cylinders? just regular engine oil?
- roy-b-boy-b
15 Jun 2013 10:50
I would put the lightest oil in I could find.
- SeattleKZ
15 Jun 2013 10:59
What about two stroke oil? I was thinking that since that is meant to burn it might be good plus it's really thin
- mtkawboy
18 Jun 2013 19:26
Put a bunch of Marvel Mystery Oil in the cylinders & let it set a week. Before you start it take the plugs out & spin the motor over to blow out the excess oil. Start it up & ride it, it should loosen it up. if that dont do it plan on taking it apart. It will smoke like crazy for a while but if that dont do it I dont know what will.
The following user(s) said Thank You: trianglelaguna
18 Jun 2013 19:50
I wonder if using Kroil in place of the Marvel Mystery Oil would work if the Marvel doesn't free the rings? I don't know how well it would burn when you start the engine or if it would have an adverse effect on the motor oil. Ed
- bluej58
18 Jun 2013 20:27
I used Marvels on my engine that sat for 20 years and I'm closing in on 10,000 miles with no problem.
The nice thing about Marvels is you can add it to the oil or the gas with no ill effect,
that's what it is, an additive.
JD
JD
78 KZ1000 A2A
- trianglelaguna
19 Jun 2013 02:24
maybe stomp on it once in awhile for short bursts too
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- kzz1king
19 Jun 2013 15:34
Can a bike be ridden any other way?
trianglelaguna wrote: maybe stomp on it once in awhile for short bursts too
Home built KZ1000 turbo setup
- MDawnz1
20 Jun 2013 03:23
Your question was you were not comfortable riding it on a long trip ?
So don't !
If your ride now is around the block,
keep working on it,
ride a little further next time,
And so on and so on,
Just keep working and one day you will be able to go wherever you want too.
So don't !
keep working on it,
1974 Z1a, still 903
- Motor Head
My question is...
Was this compression test done with it warmed up, and the throttle wide open? If not this will be a low reading. Also altitude will play into the reading, so are you much over sea level?
There are some combustion chamber, De-carbonizers on the market. Such as the Mopar Combustion Chamber Cleaner, from the Chrysler parts department.
