Gased and hosed!!!!
- pocycle
Gased and hosed!!!!
14 Jun 2013 23:36 - 14 Jun 2013 23:39Attachment IMG_2268.jpg not found
So I pulled my bike apart to clean carbs and fix some electrical stuff and paint..... took to long and wound up moving in the middle of the process and lost some stuff!! I am trying to figure out hot to reconnect the gas lines from the tank and the repair manual is not very clear. If anyone could give some direction on this it would be greatly appreciated... pics would be awesome!! Thanks all...
Last edit: 14 Jun 2013 23:39 by pocycle. Reason: another pic
- steell
Re: Gased and hosed!!!!
15 Jun 2013 00:53
Well, I know it's not a KZ750 twin, because it has a fuel level sender, and I don't think any KZ before 1980 had one. So that limits it to 1980's KZ's (I'm assuming it's a KZ because this is KZR), and several models had either fuel low lights of guages.
Got to admit, you got me stumped, just can't figure out what model you have.
15 Jun 2013 07:46
From posts in other topics, would guess 1991 kz1000p.
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
- P21
15 Jun 2013 09:22
ok here it goes
1-drain only for sender (if develops leak)
2-fuel line (run under the back bone (frame)
3-vacume for petcock goes to number 2 carb (way it is now your petcock is bad and runs on prime only)
4-tank vent only
numbers (1) and (4) need hoses run to right side of engine and down to back of motor there is a metal ring to hold theses in place
4-tank vent only
Attachment TankLines.JPG not found
Kawasaki KZ 1000 Police (2002) P21
