Holy CRAP gas everywhere! A little help here guys!
- Killman
- Now with 99% more ducks
14 Jun 2013 16:57
Girlfriend told me she smelled gas before she headed out to work this morning. Taking the only keys to her Kz750 Ltd with mikuni carbs.
I walked into the garage to find that the bike had randomly started leaking a little gas out of the fuel line attachment to the petcock. The clamp is behind the petcock where I can't get at it. I snugged the fuel line as tight as I could and drained the overflows. Just a little gas came out then stopped, I wanted to drain it all out into a jerry can, but no dice.
But just now I smelled a LOT of gas, (attached garage) went out to find gas leaking out of the pod filters now, drained the overflows again. I'd just rip off the fuel line and use a longer spare line to drain, but I'm worried about gas pouring out.
Gonna wheel the bike out into the driveway. Worried about the fumes. Can't find the manual, (just moved into the house) WTF?
Help, pretty please?
1983 kz440 ltd
Quack
Quack
- daveo
Re: Holy CRAP gas everywhere! A little help here guys!
14 Jun 2013 17:07
:huh: A temporary solution may be to clamp the fuel hose with a vice-grip to stop, or at least slow the gas flow.
NO SPARKS!!!
NO SPARKS!!!
1982 KZ1100-A2
- MFolks
14 Jun 2013 17:13
If you're using gas with Ethanol(most are), it's nasty on any rubber part of motorcycle fuel systems. It will cause plastic fuel filters to fail, as the glue holding the filter element will be attacked, coating it with the adhesive, rendering the filter useless.
Ethanol can cause fuel lines to swell internally, reducing fuel flow,and will soften the rubber tipped float bowl needles. It will eat pinholes in the vacuum operated petcock(gas tank valve), and in CV carb diaphrams.
About all you can do is make the fuel systems parts made of rubber, "A Time Change Item", replacing the parts every so often.
I've read the Silicone fuel lines resist Ethanol the best, and other manufacturers are creating similar products.
Find if possible, Ethanol free gas stations for your bike.
- Killman
14 Jun 2013 17:49
Well between what I managed to get into the jerry can and what spilled onto the garage floor and driveway, I think that the gas is just about out of the bike :laugh:
Oh well, guess I'll spend the rest of the day finally unpacking the shop, so that I can actually lay hands on stuff, (like a manual and a fire extinguisher) and maybe even do some actual work on my bike finally.
I just about had a coronary hitting the button for the garage door opener though. The fumes were thick. Gonna have to figure out some ventilation in there besides just opening the door to the house and then the bedroom and kitchen windows. Pretty sure that could've been unpleasant if it had been leaking full bore while we were still asleep.
Her bike is givning me fits though. Won't start, can't get the pipes in the right order and now it decides to just randomly start leaking gasoline from everywhere. I think it might be haunted by one of my ex-girlfriends. :whistle:
1983 kz440 ltd
Quack
Quack
- Powerstroke_fan
14 Jun 2013 21:47
I would also check the oil and cyclinders to insure no gas went into the crankcase or cyclinder.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Killman
14 Jun 2013 22:52
Aw bloody hell, Powerstroke, I didn't even think of that. :S
Oh well, I was going to give it an oil change anyways.
1983 kz440 ltd
Quack
Quack
- Powerstroke_fan
15 Jun 2013 07:32
you could just perform a sniff test to see if theres gas in the oil with out changing it.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
