NEED 1981 KZ1000 Alternator Rotor
- timmorrison
14 Jun 2013 12:04
Hey,
I've been trying to find a replacement Alternator Rotor for my '81 KZ1000 LTD - K.
Can't find one anywhere. Does anyone have any ideas or suggestions of where to look???
THANKS!!!
THANKS!!!
Re: NEED 1981 KZ1000 Alternator Rotor
14 Jun 2013 13:41
No eBay APP ID and/or Cert ID defined in Kunena configurationThat is listed on Kawasaki.com as still being an "Active" part, so any dealer can order it for you, but they are pricey. Ronayers.com lists it a $329. There is a new old stock one on eBay (see below) but they are asking a bit more than ronayers. Maybe a bike breaker will have a used one in good shape as the same part number was used for Police bikes up until at least 2001. Ed
Attachment 00000_2013-06-14.jpg not found
- Goalieguy35
- JJ
14 Jun 2013 16:09
i have what you need. will attach a photo later.
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
- MFolks
14 Jun 2013 16:18
There a company in England that has new rotors, but I'm unsure of the cost.
www.electrexworld.co.uk/acatalog/Online_...ogue_Rotors_188.html
- MFolks
14 Jun 2013 16:19
Try this company in England:
- daveo
14 Jun 2013 16:42 - 20 Jun 2013 09:26
No eBay APP ID and/or Cert ID defined in Kunena configurationBeware the magnets on these OEM 21007-1036 rotors!
See: www.kzrider.com/forum/2-engine/540846-oh-brother#540846
I had one break loose, but fortunately discovered it before any extensive engine damage could happen. Replaced it with an Electrex RO3 rotor, which was expensive and required some part modifications as it was not a direct-fit
The original Kawasaki rotor bolt had to be shortened about 3/8", and material on the starter clutch gear hub had to be removed due to an internal taper position difference from OEM at the crank. It was well-worth the effort though.
Just spotted on ebay 6/20/13:
1982 KZ1100-A2
Last edit: 20 Jun 2013 09:26 by daveo. Reason: modify text
