sending unit
  • BxRad925
  • BxRad925's Avatar Topic Author
sending unit
11 Jun 2013 21:28
#591826
dose anyone know where to get a sending unit for a 1982 kz750e i cant find one anywhere
Re: sending unit
11 Jun 2013 21:41
#591828
Sending unit for what function? Oil pressure, neutral indicator, speedometer, etc. Ed
  • BxRad925
Re: sending unit
11 Jun 2013 22:09
#591838
oil sending unit
Re: sending unit
11 Jun 2013 22:18 - 11 Jun 2013 22:19
#591842
Here are 2 places that have it in new old stock; plug in the part number (16144-006) for the quantity on hand and prices. I've dealt with both places and was always pleased.
www.themotorcyclepartsoutlet.com/cgi-bin/store/index.cgi
www.nwvintagecycleparts.com/search-resul...arch.x=9&search.y=11
Attachment 00000_2013-06-11-3.jpg not found
Last edit: 11 Jun 2013 22:19 by 650ed.
  • BxRad925
Re: sending unit
11 Jun 2013 22:37
#591847
thank you and where did you find that diagram i would like to get a pdf repair book for it
Re: sending unit
11 Jun 2013 23:08 - 11 Jun 2013 23:08
#591853
I got it at Kawasaki.com. If you go to Kawasaki.com on left side put cursor over "Owner Information" then on drop down menu click on "Parts Diagrams." The click "Continue" next to "Motorcycles" and click on model/year/etc. on drop down. Once you get the list of parts for your bike you can click on the category of parts - such as "Air Cleaner" and you will see a diagram of all the parts for that category. Then when you click on an actual part number on the list under the diagram it will say if the Item Status is "Active." If it is “Active” Kawasaki still sells the part through dealers. Also, at that little page you can click on the yellow highlighted question mark for a cross reference of which bikes share that part or click on the red highlighted S to see earlier part numbers for the same part. Ed
Last edit: 11 Jun 2013 23:08 by 650ed.
  • martin_csr
  • martin_csr's Avatar
Re: sending unit
12 Jun 2013 10:47
#591916
Here's a site w a manual & wiring diagrams. Scroll down & click "The Bible" link. mbsween.bike-night KZ750L3 page
Some of the wiring diagrams are mislabeled in the links. An H2 is an 81 & an H3 is an 82.
search tags mbsween KZ750L3
For diagrams & cross-referencing, I use Kawasaki.com & Partzilla. The partzilla diagrams are easier to use, but they don't have a diagram drawing in every case (kind of annoying at times) & they tend to lump too many bikes together in the cross-ref in some cases. Double-check the x-ref at the Kaw site before getting anything anywhere. Z1Enterprises.com can get any available oem parts. Some guys like RonAyers.
