Oil leak - Front of engine, 1982 Spectre
- mcguest12
10 Jun 2013 13:51
I have found an oil leak on the front of my engine. Located behind the headers, halfway down the cylinder block.
First question, what is this? Second Question, Is it just a gasket or O ring that would cause the leak.
All help will be great.
- gwolever
Re: Oil leak - Front of engine, 1982 Spectre
10 Jun 2013 14:19
Sounds like the connection for your tachometer cable is leaking maybe. Probably check that first. Tighten or possibly replace o-ring.
1982 KZ1000 CSR
11 Jun 2013 01:25
If not already done, would check for loose nut on exhaust clamps.
Pics?
Pics?
- etbike3135
11 Jun 2013 08:25
More then likely its a rubber seal located between your cylinder block and head. I dont know why but those things dry out like nobodys business. Your have to take the head off and put a new head gasket and o rings if thats your problem,
1973 Kawasaki Z1
18 years in dragbikes
- Spectre1982
11 Jun 2013 15:03
+1 on the head gasket. Mine was doing the same thing until I got a gasket set. I have an '82 and mine has an electronic tach. There is no tach cable.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
- crh
- Banned
13 Jun 2013 07:03
Head gaskets were a common problem on 750's, even when they were new. We did lots of them under warranty.
Tach Drives [which your bike should't have] don't generally leak by the O Ring. The seal inside the tach drive wears out from the shaft spinning. In such situations you replace the seal and the outer O Ring.
