Modified Kz650 need cooler plugs ?
  • KZB2 650
  • KZB2 650's Avatar Topic Author
07 Jun 2013 09:45
#591193
Got the 700cc kit 10 to 1 with a stock 750 cam, header, pods, Dyna, coils etc running vg and am wondering if I should go with a step cooler plugs...... N-3 Champion or a NGK 8 instead of the 7. Also forgot about the opening them up to .037 or so on the gap too. You guys like this idea too ?
I do ride it a little easier than most and in cooler temps 65 to 85 but I do often feel the need for speed.
What you guys think? Thanks.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • baldy110
  • baldy110's Avatar
Re: Modified Kz650 need cooler plugs ?
07 Jun 2013 13:28
#591209
Nope just use the stock ones. I have a 78 KZ650 modded with a 720cc kit, GPz750 cams, 4 into 1 pipe and pod filters, Dyna S ignition and Dyna green coils. Been using the stock plugs for 30 years now with no issues. I have tried cooler and hotter plugs over the years but always went back to the stock heat range.
08 Jun 2013 11:40 - 08 Jun 2013 11:43
#591318
Would follow factory spark plug recommendations as to heat range and gap.
FSM usually includes an explanation, such as the following example --
Good Fortune! :)
Last edit: 08 Jun 2013 11:43 by Patton.
  • KZB2 650
08 Jun 2013 12:31
#591323
Ok thanks guys I'll stick with normal and .032 on the gap, and Baldy from day one I've loved your 650 was terrible news about the wreck.
1978 KZ650 b-2
  • baldy110
  • baldy110's Avatar
08 Jun 2013 14:56
#591330
Thanks and FYI I have it up and running again. Finished it earlier this year.
[IMG
