clutch pushrod
  • chonus
  • chonus's Avatar Topic Author
clutch pushrod
06 Jun 2013 21:46
#591147
Im assuming they're supposed to be perfectly straight right? I have two that are bent in identical ways and I just have to assume its a coincidence. also.. arent you supposed to be careful removing it. Ive heard the bearings inside can become dislodged
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
  • MFolks
  • MFolks's Avatar
Re: clutch pushrod
06 Jun 2013 21:59
#591149
Yep, they should be straight, and the only bearing I think you mean, is a ball bearing, acting as a rotating pusher when the clutch lever is squeezed. A few riders have replaced the clutch pusher shaft from www.z1enterprises.com and others have used a drill rod blank(cut down to fit the correct length) I'd think 3/16" diameter drill rod would work, but check the diameter of your old push rod first. Most machine shop suppliers sell drill rod, as it's a precision made shaft. Some are oil hardening, others can be water hardened, or air hardening. Any of them would be needed to be heated to hardened.
The following user(s) said Thank You: bluezbike, chonus
  • APE Jay
  • APE Jay's Avatar
Re: clutch pushrod
07 Jun 2013 21:59
#591278
They have the good ones at Z1.
  • bluezbike
  • bluezbike's Avatar
Re: clutch pushrod
08 Jun 2013 03:04
#591299
Don't worry about the ball bearing falling out or ending up in the gearbox....it is trapped in the tunnel the clutch pushrod moves in which is through the input shaft and that is sealed off from everything. The only way to get to it is to take off the clutch outer plate. And yes the pushrod does have to be straight.
79 KZ 1000 LTD
  • 2wheeladdict
  • 2wheeladdict's Avatar
Re: clutch pushrod
08 Jun 2013 14:44
#591327
Good time to upgrade the pusher also to the roller bearing model. My pushrod was worn 1/4 inch short and had to pull it from the clutch side due to mushrooming.
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
