Engine vacuum.
  • kimsmith4807
  • kimsmith4807's Avatar Topic Author
Engine vacuum.
06 Jun 2013 18:51
#591131
Bike is a 1981 KZ1000-K1 LTD? What kind of vacuum would I see in either cm Hg or inches of water if I connect a vacuum gauge to one of the nipples on my carbs? Trying to compare a factory number to where I am now with the 3X cams and overlapping valves.
1981 KZ1000-K1 LTD
  • baldy110
  • baldy110's Avatar
Re: Engine vacuum.
06 Jun 2013 20:36
#591142
The gauge will just bounce so bad you won't be able to read it.
  • Motor Head
  • Motor Head's Avatar
Re: Engine vacuum.
06 Jun 2013 22:17
#591154
I'm with Baldy on this one. I have a Uni-Sync tool which goes over the Airhorn on a carb, but it is a pretty simple sync tool. There are the purpose built carb sticks, and several home made versions. I have found the Vacuum balance tool which cost like $5 to make works real good. Its in "File Base" and uses a yard stick, some clear tube and ATF. If the fluid flows in one direction,when hooked to two carbs, then it is a stronger pull on vacuum.
As far as actual #'s to look at. I would think you would need to have the 4 gauges, with the restrictions to see each individual cylinders vacuum. But to compare you would have had to do a before and after on the same bike, with the same Vacuum set up.
Cams will lower the Idle vacuum, increase the port runner reversion. Common with higher duration cams, late closing Intake. Gives much more top end though, a trade most HP junkies will make. ;)
Re: Engine vacuum.
06 Jun 2013 22:28 - 06 Jun 2013 22:29
#591157
Vacuum gauges will work fine but only if they have dampers on the vacuum lines. Otherwise they will bounce with each intake pulse. Here's what I use. Ed
Attachment IMG_0891_2013-06-06.JPG not found
Last edit: 06 Jun 2013 22:29 by 650ed.
  • 893cv
  • 893cv's Avatar
Re: Engine vacuum.
07 Jun 2013 00:42
#591172
I have had a VDO vacuum gauge on 2 of my bikes. I was always suprised to see how low the running vacuum was at road speeds. My cars will pull 10 + in. Hg, but the bikes only 4 to 5. To get the highest readings you will need to have good leakdown % and set valves to the wide end of the spec.
1980 kz1000 LTD
1978 Z1R
  • LarryC
  • LarryC's Avatar
Re: Engine vacuum.
07 Jun 2013 19:24
#591255
kimsmith4807 wrote: Bike is a 1981 KZ1000-K1 LTD? What kind of vacuum would I see in either cm Hg or inches of water if I connect a vacuum gauge to one of the nipples on my carbs? Trying to compare a factory number to where I am now with the 3X cams and overlapping valves.
Kim,
To answer your specific question.....With the relatively long duration of your cams it's likely your vacuum readings at idle will be around 5-6" Hg. That does depend on how they are timed though.
Larry C.
The following user(s) said Thank You: kimsmith4807
  • kimsmith4807
Re: Engine vacuum.
08 Jun 2013 14:31 - 08 Jun 2013 14:34
#591326
Kim,
And what would it have been stock, roughly?
1981 KZ1000-K1 LTD
Last edit: 08 Jun 2013 14:34 by kimsmith4807.
