1979 KZ750 Twin Clutch Cable Spring?
  • lroberts
  • lroberts's Avatar Topic Author
05 Jun 2013 20:26
#590980
I am placing my bike back together and it looks like I am missing the small spring that goes on the end of the clutch cable. Does anyone have a clue what this spring would be called and or where I could pick one up?
Thanks!
  • Twist1
  • Twist1's Avatar
Re: 1979 KZ750 Twin Clutch Cable Spring?
06 Jun 2013 00:51
#591018
You should be able to pick one up at any good hardware store-3/8 by 2 1/4. You don't want a real stiff one-if you cant compress it between your thumb and fore finger, its too stiff-good luck.
Bikes I own,76 KZ 750 Twin-79KZ750 Twin (6700 actual miles)-83 KZ 750 K1 belt drive chopper
The following user(s) said Thank You: lroberts
  • lroberts
06 Jun 2013 08:34
#591044
Can anyone take a closeup pic of this spring on the clutch cable installed so that when I go looking for one I can kinda match it up?
MAJOR BIG THANK YOU!!!
