back fire
- deezy
back fire
05 Jun 2013 13:10
having problems with my 77 kz650.. recently when I start my bike.. start riding, between 3-4 rpm bike starts to spit & pop.. but after bout twenty min of riding it starts to smooth out... just curious if any body has any ideas...
- baldy110
Re: back fire
05 Jun 2013 17:08
If the bike ran good and then started to act up like that I would check for vacume leaks around the intake manifolds. Spray carb cleaner around the manifolds as the bike is running and if the RPM's go up then you have a vacume leak.
Re: back fire
05 Jun 2013 17:26
Have you checked and lubed the timing advancer? Maybe it's sticking but breaks free after running a while. Ed
