tail light problems
- gravyl17
tail light problems
03 Jun 2013 22:57
Just wondering about my tail light only lighting up when braking. Is the rear light only a brake light or should it light up at night with the lights on. This may sound like a dumb question but don't understand.
- Mid life crisis
Re: tail light problems
03 Jun 2013 23:09
Your tail light should certainly light up without the brake on. It is a tail/brake light.
Those bulbs have two filaments. Have you checked to see if one is burned out? One filament will work even if the other doesn't.
If that isn't the case, you may have to test your wires to see if you are getting power.
This post should be in electrical as compared to engine, but I am sure nobody will be too upset!!
- bountyhunter
04 Jun 2013 00:41
There is a 8W filament for the tail light and an 18W filament for brake. The tail light could be burned out and brake still work.
