Valve Cover Bolts Torque Amount
  • mcguest12
  • mcguest12's Avatar Topic Author
03 Jun 2013 16:22
#590678
How much do I torque the bolts to on the valve cover? I have to replace the gasket and don't want to overtorque the bolts.
Any help would be great.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Valve Cover Bolts Torque Amount
03 Jun 2013 17:17
#590688
According to the factory service manual, maximum torque is 69 in-lbs...assuming your motorcycle is the same as your avatar (KZ750-N model)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
03 Jun 2013 17:19
#590689
I believe yours are 6mm bolts like those on my KZ650 valve cover. The Kawasaki Service Manual calls for 61 - 78 INCH lbs. of torque. Be sure to use a torque wrench calibrated in inch pounds. Using a foot pound wrench and converting the torque to inch pounds is very risky because you will be at the very bottom of the wrench's scale and torque wrenches are not very accurate there. Ed
