1985 kz1000 police Bike got the vibration
- davem
01 Jun 2013 13:02 #590280
by davem
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
1985 kz1000 police Bike got the vibration was created by davem
This is a project im working on and ist completely stock. It starts right up and runs good but when i rev the engine i feel vibration in my feet on the floor boards. same thing when im riding down the road. When ideling its there but barely noticeable.
Any ideas what would cause this?
Thanks
Thanks
1979 Kz1000 B3 LTD
- Jompa
01 Jun 2013 13:23 #590284
by Jompa
Replied by Jompa on topic 1985 kz1000 police Bike got the vibration
Reasen ?
It's a KZ 100, and they vibrate, ecsoecially between 2500 -3000 rpm.
If you just can feel vibration, and not worse than feel, its normal.
- daveo
- Thank you received: 655
01 Jun 2013 13:45 - 01 Jun 2013 19:16 #590288
by daveo
1982 KZ1100-A2
Replied by daveo on topic 1985 kz1000 police Bike got the vibration
:huh: :woohoo:
I was getting a vibration with the stock exhaust system, and wasn't able to isolate the problem until it was removed. Then I found the culprit...loose inner down-pipe on #4. Actually, it wasn't loose, but just close enough to the outer one to exaggerate a minimal vibration. It felt like the motor was going to blow when cruising around 4000rpm.
Not any more.
Not any more.
1982 KZ1100-A2
Last edit: 01 Jun 2013 19:16 by daveo.
- davem
01 Jun 2013 15:06 #590300
by davem
1979 Kz1000 B3 LTD
Replied by davem on topic 1985 kz1000 police Bike got the vibration
I have a 79 1000 ltd I'd doesn't feel like this. My feet go a little numb.Jompa wrote: Reasen ?
1979 Kz1000 B3 LTD
- APE Jay
- Banned
- Thank you received: 58
02 Jun 2013 20:53 #590524
by APE Jay
Replied by APE Jay on topic 1985 kz1000 police Bike got the vibration
Could be a twisted crank. Use a TDC tool and degree wheel and find TDC on cylinder #1 and zero out the wheel. Then move the TDC tool to #4 and see where TDC is. It should be the same, or the crank is twisted.
- davem
02 Jun 2013 23:21 #590580
by davem
1979 Kz1000 B3 LTD
Ok ill try that. If my cam chain is loose could that cause it? I think I here the cam chain a little bit. I was gonna change the automatic tentioner to a manual one.APE Jay wrote: Could be a twisted crank. Use a TDC tool and degree wheel and find TDC on cylinder #1 and zero out the wheel. Then move the TDC tool to #4 and see where TDC is. It should be the same, or the crank is twisted.
1979 Kz1000 B3 LTD
