- Thank you received: 20
KZ700 Cylinder Head help
- crh
- Banned
03 Jun 2013 17:57 #590696
by crh
Replied by crh on topic KZ700 Cylinder Head help
That's cool Hard to tell from the pic exactly but once that broken stud is out, you're home free IMO. Might need to put a washer or two over the stud for the clamp to seat against. Often the clamps don't need to be tightened to the point where they touch though.
I had a similar situation on my bike only it was #2 cylinder. I fixed it without pulling anything apart. Took a little longer though because it wasn't as easy to get to. Good Luck! Hope it goes easy for you.
- Dr. Gamma
- Thank you received: 680
03 Jun 2013 18:58 - 03 Jun 2013 19:58 #590703
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic KZ700 Cylinder Head help
Hate to break the bad news to you, but no welder worth their salt will even try to weld that area while the head is on the bike. 75% of a good weld is surface preparation. The whole area around to be welded must be free of oil, paint, and other contaminants. Plus they usually grind away all the weak looking metal around the area they are going to repair too. If you don't,you end up with a weak and a goober looking weld.
When you find a welder, or a machinist extraordinaire, you always remember to bring them a bottle of their favorite liquor no matter the cost at Christmas and their birthday. You would be surprised how much cheaper their prices get when you do that!!!!
Last edit: 03 Jun 2013 19:58 by Dr. Gamma. Reason: badd grammer
- Marklorenzo
- Thank you received: 1
03 Jun 2013 20:53 #590715
by Marklorenzo
1984 KZ700 A1
Replied by Marklorenzo on topic KZ700 Cylinder Head help
I've thought about drilling it out and putting a 8mm stud in. Idk tho how much meat I can go without drilling into a bigger mess. Do they make a longer stud than normal mayne that goes from 8mm to 6mm? So frustrating.
1984 KZ700 A1
- zukdave
- Thank you received: 229
03 Jun 2013 23:09 #590740
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic KZ700 Cylinder Head help
Think I'm with CRH on this.
Get the broke bolt out then drill and tap the
hole a little deeper longer stud your done.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Marklorenzo
04 Jun 2013 06:25 #590777
by Marklorenzo
1984 KZ700 A1
If I do drill and tap a stud in I will need a significantly longer stud. Where would I find one?
1984 KZ700 A1
- Marklorenzo
04 Jun 2013 18:05 #590849
by Marklorenzo
1984 KZ700 A1
Well they are going to fix it. Going to clean area and weld a small block to engine block. Most recommended welder in my town. Guess its worth a shot. Will upsate with pics.
1984 KZ700 A1
- Thank you received: 797
05 Jun 2013 09:52 #590921
by 531blackbanshee
Replied by 531blackbanshee on topic KZ700 Cylinder Head help
hope it works out for you.
keep us posted,
keep us posted,
