Clutch lever adjustment problems
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Clutch lever adjustment problems
02 Jun 2013 09:34
#590411
I once seen where someone had put two ball bearing in there pusher and it wouldnt allow it to work.
1977 KZ 1000 work in progress
  • freakinbike
  • freakinbike's Avatar
03 Jun 2013 00:44
#590605
Did you happen to find a new cable? Not sure if you read on my thread, but it was mentioned that it could be breaking in the casing (these cables are old)
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
  • DBSoundman
  • DBSoundman's Avatar Topic Author
03 Jun 2013 12:26
#590646
I have one on order along with a new adjustment screw for the lever.
  • freakinbike
08 Jun 2013 16:40
#591333
Have you had any luck? I'm still out of ideas and haven't had any time to work on it
1973 VW Bus
09 Jun 2013 01:42
#591390
Good Fortune! :)
  • DBSoundman
11 Jun 2013 19:20
#591795
I have the new clutch cable and adjustment bolt in but waiting on the cam still. I'll post as soon as I have a result of replacing those.
  • DBSoundman
21 Jun 2013 00:29
#593322
So I finally got all the parts in. The cam was shipped in from Africa... Anyways, I put it all together- new cable, cam, and adjustment bolt. I put a nut on the bolt on both sides to get the cam raised since it wasn't flanged like the factory one. Works like a charm. I'll post after I ride it tomorrow. I still would like to get a ball bearing to put between the lever and the push rod so I can set the lever farther in the housing but til then this looks like it will work.
