Springs - Valve and Clutch
- RobK
30 May 2013 14:17 - 03 Jun 2013 13:36
Anyone know how to tell the difference between clutch springs and (interior) valve springs? I bought all these parts and there were springs everywhere, some new, most used, but I'd like to be able to figure out what is what.
Specifically the ones I'm curious about are at the front (bottom) of the pic below. If there is a difference in dimension, it seems slight.
Many thanks,
Rob K
Attachment springs.jpg not found
Many thanks,
Rob K
My mule's got the funny idea you're laughin' at him. Now if you apologize like I know you're gonna...
Last edit: 03 Jun 2013 13:36 by RobK.
- DoubleDub
Re: Springs - Valve and Clutch
30 May 2013 15:37
Might be tough - I used the inner valve springs as beafier clutch springs - they are very close in size.
- turboking
30 May 2013 16:59
the red ones in your pic look to be clutch springs?..... the only real way to tell is check them at installed height with a valve spring pressure tester........ and check pressure in compressed (clutch pulled ) height.....and coil bind.......not every one has access to one of these... I have my own :whistle:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- APE Jay
30 May 2013 20:32turboking wrote: the red ones in your pic look to be clutch springs?..... the only real way to tell is check them at installed height with a valve spring pressure tester........ and check pressure in compressed (clutch pulled ) height.....and coil bind.......not every one has access to one of these... I have my own :whistle:
I have two of them....so there!!!
- RobK
31 May 2013 04:07APE Jay wrote:turboking wrote: the red ones in your pic look to be clutch springs?..... the only real way to tell is check them at installed height with a valve spring pressure tester........ and check pressure in compressed (clutch pulled ) height.....and coil bind.......not every one has access to one of these... I have my own :whistle:
..and I have none! Looks like I may be shopping for one.
- crh
- Banned
- turboking
31 May 2013 08:46
last time I checked they were over $1,000.00 new.......
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
31 May 2013 08:49
I remember someone made a small one that cost like $100 and could be used in a vise ...... can't remember who though :S
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
31 May 2013 08:56 - 31 May 2013 09:05
checked and summit sells this one for $72.00.... :woohoo:
static.summitracing.com/global/images/pr...-66834.jpg?rep=False
Proform Mini Valve Spring Testers 66834
Proform Parts 66834 - Proform Mini Valve Spring Testers
Click to Enlarge Image
Video
$71.97
+Compare
Valve Spring Tester, Mini, Vise/Arbor Mount, 0-700 lbs/in.Range, Each
See parts for Proform Parts
Part Type: Valve Spring Testers
Overview
Brand: Proform Parts
Manufacturer's Part Number: 66834
Product Line: Proform Mini Valve Spring Testers
Summit Racing Part Number: PRO-66834
UPC: 037995318346
Valve Spring Tester Style: Mini for vise/arbor
Spring Pressure Tested: Variable
Spring Pressure Range: 0-700 lbs./in.
Quantity: Sold individually.
In-Store Pickup: Choose In-store pick-up (OH, GA, NV) on our web site.
Proform mini valve spring testers are the affordable, portable way to test springs. The hex-design body is very versatile, so they can be used in either a vise or an arbor press. The testers feature a rubber gauge protector to help keep the gauge housing protected.
Video
$71.97
+Compare
Overview
UPC: 037995318346
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
Last edit: 31 May 2013 09:05 by turboking.
- steell
31 May 2013 15:30 - 31 May 2013 15:34crh wrote: They're not cheap
Eh? I think I paid less than $30 for mine, via eBay (NOS). It's the free standing one that does not require a vise, but does require a 3/8" torque wrench (old style, CRS in effect at the moment).
Does a fine job, and fast.
This ones a little more than I paid, but identical.
Last edit: 31 May 2013 15:34 by steell.
- slayer61
- KZR FLAG RELAY CARRIER #62
31 May 2013 16:34
That all seems fine and good, I have had some success putting the bathroom scale on the drill press, measuring spring height and comparing to force/pressure on the scale. Works for me! Paul
