Rings or valve seals?
- Kitten Tooth
29 May 2013 20:24
When i rev the motor on my 81' KZ1000, a small amount of black smoke comes out (indicating a rich mixture). when i let off the throttle the RPMs go down and right as its hitting idle it belches out white oil smoke. all my spark plugs look good. It runs good but doesnt seem to have the power it did last summer. any ideas on what might be wrong?
Thanks guys,
KT
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Powerstroke_fan
Re: Rings or valve seals?
29 May 2013 20:47
A simple compression and leak down test would verify that it is the rings.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Kitten Tooth
29 May 2013 21:40
fun stuff
i will go cry now. nah ill rebuild it this coming winter. cylinder 2 is getting about 90-100 psi compression. thats not very good.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Powerstroke_fan
29 May 2013 21:43
Sorry to hear that. How did you perform this test? Throttle open?Engine cold? Dry cylinders?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- richard_oxon
29 May 2013 22:21
i know on a car worn valve seals guides will make smoke on decel and worn rings will make smoke on acel however as others say a compression test will show whats up ..
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
- Powerstroke_fan
29 May 2013 23:20
I never said it wasnt valve seals, I just recommened a compression test.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
29 May 2013 23:24Kitten Tooth wrote: fun stuffi will go cry now. nah ill rebuild it this coming winter. cylinder 2 is getting about 90-100 psi compression. thats not very good.
If you can swing it also do a leak down test. That should help verify if it's the rings rather than possibly a valve. Ed
- Spectre1982
29 May 2013 23:42
I rebuilt my top end last winter. It wasn't as hard as I was expecting. My valves weren't sealing up well. Had about 90 psi in Cylinder No. 1. For parts I paid $250 for rings, gaskets and viton guide seals. I also had to buy a bunch of specialty tools that set me back more than that, but now I've got them forever. I'd say the most time consuming part of the whole job was scraping the 31 year old gaskets off the deck. Good luck on the rebuild.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
- bountyhunter
29 May 2013 23:59
I'd bet on rings. Valve seals leak a pretty constant amount of oil and will typically puff on start up but not so much puff up when revving. That sounds more like rings, although both could be bad.
- bountyhunter
30 May 2013 00:01Yep. I recall it was 3 or 4 hours removing the base gasket under my cylinder.Spectre1982 wrote: I'd say the most time consuming part of the whole job was scraping the 31 year old gaskets off the deck.
