'79 kz400 top-end rebuild
- kzzkkzzk
28 May 2013 19:21
so i was told by the previous owner of my newly bought kz400 that there is a leak at the head gasket on the block. that said, the plan is to replace the gasket. so what is the plan of action while i am in there? should i look to change anything else while the motor is out of the frame?
also, i'm having a bit of a hard time finding parts specifically for my bike. it seems most parts are for 77-78, never reaching 79. am i looking for the wrong year, or will most of, if not all, parts listed as 78 work on a 79?
Re: '79 kz400 top-end rebuild
28 May 2013 19:41
Is there some reason for removing the engine from the frame? That should not be necessary just to replace the head gasket. Ed
- kzzkkzzk
28 May 2013 20:10 - 28 May 2013 20:11
well, i initially wanted to disassemble the entire motor and have a look-see as to what's going on in there. the odo reads 26k, and me being a stickler for a properly maintained motor, i'd like to see what i can do to make sure it runs like a swiss watch. i don't know if the previous owner(s) have taken good care of it, so i'd like to inspect it myself. if that means stripping it and rebuilding, then so be it. but if you more experienced guys think it's unnecessary (kind of like how i just learned it is for replacing head gasket!), then i'll cease and desist.
also, i found this gasket kit and this bolt kit for the rebuild. anything else i need for the job?
Last edit: 28 May 2013 20:11 by kzzkkzzk.
- Nebr_Rex
29 May 2013 00:28
Have you seen this leak?
What is leaking?
Maybe a pic.
Have you done a proper compression test?
And like I was told long ago,..if it ain't broke don't I fix it.
What is leaking?
Maybe a pic.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
29 May 2013 07:59
....and if if ain't broke don't break it.
- kzzkkzzk
29 May 2013 14:37
yessirbob. heck, i just noticed that there's a leak from the drain plug as well. but unfortunately i did not get to take a picture this morning. the entire bottom of the motor has a layer of oil and dirt. while i'm at it, the drain bolt is lefty-loosey, right? i've read some things on these motors are... backwards, that's why i ask. i couldn't get the drain bolt off for the life of me. think i'll use a breaker bar tonight.
i am going to perform a compression test tonight. what is a good range for compression? will update with results.
29 May 2013 16:31
Yes, lefty-loosey. (Counter-clockwise to loosen.) Ed
- kzzkkzzk
01 Jun 2013 18:45 - 01 Jun 2013 18:52
alright alright, so i took the head and barrels off and disconnected the pistons. everything inside around the crank looks clean as a whistle, and the only parts that seem to need a cleaning are the pistons + combustion chamber on the head.
i'm planning on going at the carbon with some carb cleaner and a SS brush. if there's a better way to do it, i'm all ears.
also, there was a leak at the head due to a ruptured gasket. glad i took it apart to where i did, because the gasket for the barrels was pretty nasty, too.
edit: also, does anything in these pictures look like it needs to be replaced to you guys with the trained eyes?
piston rings maybe?
piston rings maybe?
Last edit: 01 Jun 2013 18:52 by kzzkkzzk.
