cam cap bolt hole stripped
  • brianrae33
  • brianrae33's Avatar Topic Author
26 May 2013 12:51
#589260
had all my cam cap bolt holes helicoiled...well one didnt really take...the helicoil is still in there..was wondering if it would be safe to drill out the hole that has the bad coil in it and timesert it or if i should try getting the old helicoil out first..? sorry for the long post...
1982 kz1000ltd
  • turboking
  • turboking's Avatar
Re: cam cap bolt hole stripped
26 May 2013 13:29
#589262
remove the helicoil first ...... grab the wire with needle nose or hemostat if possible or pry the end of the wire out with a pick and then grab it....... :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • turboking
26 May 2013 13:32
#589264
it will come out in a long strand :pinch: then do the timesert install B)
1985 GS 1150E
1983 GS 1100E
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 May 2013 14:32 - 26 May 2013 14:33
#589268
+1 on turboking's suggestion and +1 on using timeserts...they work well and I have used them on a number of cam cap bolt holes to replace helicoils. Remember to retorque at 8-10 ft-lbs (96-120 in-lbs) max. Also remember, if replacing a hole that had a dowel in it, to set the timesert deep enough to accomodate the dowel.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 26 May 2013 14:33 by Mcdroid. Reason: clarity
  • Kraz1
  • Kraz1's Avatar
26 May 2013 14:41
#589269
Click
> Timeserts
  • brianrae33
26 May 2013 16:32
#589288
just fyi...had the hole helicoiled for the 6 mm bolt...will i be able to drill it and time sert it for the same 6mm or will i need to go up to 7mm....? thanx in advance
1982 kz1000ltd
