- Thank you received: 33
neutral to first gear problem
- nickleo373
24 May 2013 18:30 #589055
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
neutral to first gear problem was created by nickleo373
Hello everyone
I have a 1981 KZ550 LTD thats not currently running. While working on it I noticed that the bike is having problems shifting from neutral to first gear. It will shift fine from first to neutral but when I shift from neutral to first the bike clicks like it has shifted but it remains in neutral. After a minute of jiggling the gear shifter up and down it will finally click into first gear. It would be greatly appreciated if anyone has an idea of what might be causing this.
Thanks
Nick
Thanks
Nick
1981 KZ550C LTD
- RedBullEnema
- Longtime Lurker/Knowledge Collecter
- Thank you received: 1
24 May 2013 19:26 #589060
by RedBullEnema
1978 KZ650-B2
Iteration 1 - Cafe seat, polished and oiled tank, plate/brake light combo.
Iteration 2 - Upgraded wiring, LED tail light, HID headlight.
Iteration 3 In Progress - Z1 seat, '09 GSX-R600 front end, ZRX1200 swingarm, and much much more!
Replied by RedBullEnema on topic neutral to first gear problem
Motorcycles in general tend to not be very fond of running through the gears without moving.
1978 KZ650-B2
- Spectre1982
- Thank you received: 9
25 May 2013 03:15 #589099
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Replied by Spectre1982 on topic neutral to first gear problem
Very true. Put your bike on the center stand. Rotate the rear wheel with your hand and try to put it in gear at the same time. It should lock in pretty easy.
1978 Kawasaki KZ200
- sig
25 May 2013 03:26 #589103
by sig
1982 KZ650H CSR
Replied by sig on topic neutral to first gear problem
He'll I can't shift up or down from neutral when it's not running and not moving on my bike.
1982 KZ650H CSR
- nickleo373
25 May 2013 17:45 #589167
by nickleo373
1981 KZ550C LTD
Replied by nickleo373 on topic neutral to first gear problem
Alright thanks guys. Good to know there's nothing broken
1981 KZ550C LTD
