KZ550 Pipe. ZX6?
- County Fair
KZ550 Pipe. ZX6?
22 May 2013 20:40
I am looking for a 4 into 1 Pipe for my 81 KZ550.
All I can find are MAC. I have never heard a mac pipe.
I have also seen some talk of putting a ZX6 header on a KZ550. But, I have not seen anyone really do it.
Any help would be great.
Thanks
Tim
Thanks
Tim
1981 KZ550
1971 CT70
www.kzrider.com/forum/11-projects/588924-kz550-mine
1971 CT70
- Beav
Re: KZ550 Pipe. ZX6?
22 May 2013 20:56 - 22 May 2013 21:07
It seems that kz650 pipes will fit with a little work. I just picked up a used 4 to 1 and I just needed to bend the headers in an inch or so to line them up. It takes a little work to line up the rear mount as well, I'll take some pictures once the paint dries.
I just noticed you have the ltd model, my bike is a kz550a so I'm not sure if everything will line up the same.
Last edit: 22 May 2013 21:07 by Beav.
- County Fair
22 May 2013 22:07Beav wrote: It seems that kz650 pipes will fit with a little work. I just picked up a used 4 to 1 and I just needed to bend the headers in an inch or so to line them up. It takes a little work to line up the rear mount as well, I'll take some pictures once the paint dries.
Thanks,
I would like to check out your pictures. Only the rear mounts should be different, from your GPZ and my LTD.
1981 KZ550
1971 CT70
1971 CT70
- County Fair
23 May 2013 19:46
When I click on that link it tells me...
You do not have permissions to access this page.
1981 KZ550
1971 CT70
1971 CT70
- loudhvx
23 May 2013 20:05
Must be something with the site upgrade. That link worked earlier when tried it, before the upgrade, but now I get the "Permission.." message.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- loudhvx
23 May 2013 20:09
Let's try it again, two ways.
kzrider.com/forum/24-wanted/588113-looking-for-kz550a-exhaust
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
23 May 2013 20:12 - 23 May 2013 20:15
Can't figure out why Patton's link no longer works. I think he is linking to a specific reply? Is that it?
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 23 May 2013 20:15 by loudhvx.
- loudhvx
23 May 2013 20:19
This link has photos of a 650header fitted onto a 550.
www.kzrider.com/forum/2-engine/580413-kz...patibility-revisited
1981 KZ550 D1 gpz.
Other links.
Other links.
23 May 2013 21:07 - 23 May 2013 21:15Patton wrote: Some info here:
www.kzrider.com/forum/24-wanted/588188-r...g-for-kz550a-exhaust
Try this version:
www.kzrider.com/forum/24-wanted/588113-l...z550a-exhaust#588188
Last edit: 23 May 2013 21:15 by Patton.
- County Fair
23 May 2013 22:26
Thanks guys
1981 KZ550
1971 CT70
1971 CT70
- GypZee
29 May 2013 14:39
Is the 750 head also dimensionally the same as the 650? If so, wouldn't the 750 header also fit as well as the 650?
83 GPz1100
85 GPz550
85 GPz550
