- Thank you received: 9
Exhaust torque
- Spectre1982
22 May 2013 15:49 #588768
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Exhaust torque was created by Spectre1982
Does anybody have the torque specs for header bolts? Found a small exhaust leak right at the header, but don't want to go too tight and break something. I looked through my FSM but didn't see the specs.
Thanks
'82 KZ750
Thanks
'82 KZ750
1978 Kawasaki KZ200
- Thank you received: 2098
22 May 2013 17:26 - 22 May 2013 17:27 #588787
by Patton
Replied by Patton on topic Exhaust torque
Pending a better specific source for the '82 KZ750, the torque table in FSM for '77~79 KZ1000 says,
"less than 43 inch-lbs."
Last edit: 22 May 2013 17:27 by Patton.
The following user(s) said Thank You: Spectre1982
- Spectre1982
22 May 2013 17:58 #588794
by Spectre1982
1978 Kawasaki KZ200
Replied by Spectre1982 on topic Exhaust torque
Thanks, Patton. After my post I found one of the nuts had vibrated off the holder. I thought I torqued it better than that. :ohmy: I'll take it out for a spin later. I'm sure that was the issue.
1978 Kawasaki KZ200
- Spectre1982
22 May 2013 21:05 #588809
by Spectre1982
1978 Kawasaki KZ200
Sound as a pound!
1978 Kawasaki KZ200
