Oil everywhere/ false sight window
- stroked64
21 May 2013 21:30 #588616
by stroked64
Oil everywhere/ false sight window was created by stroked64
This may be something simple but I can't figure it out. I took the bike for a test ride after getting the brakes back together. I got about a mile and looked down to see oil bleeding out violently. Got it back home and it looked like it was coming from the breather/ top of the crank area. Read a few things and check the "oil too high level" problem. Drained the oil and filter removed, the oil window says its still full.... so i turned it over a few times and it goes down. I repeated a few time and it stops where pictured. Nothing coming out at all.... any info?
- KZipper
- Thank you received: 3
21 May 2013 22:51 #588640
by KZipper
'81 KZ650H1 CSR
Replied by KZipper on topic Oil everywhere/ false sight window
Possibility there is sludge blocking the hole to the sight window.
'81 KZ650H1 CSR
