- Thank you received: 15
KZ piston sleeve combo
- peavylotus
- Movin on up
I need pistons and sleeves or pistons and a bore. I see some sweet deals on some combos but I wanted to know what wiggle room there is with these motors as far as campatibility.
Mine is a KZ 1000 B4 LTD
Can you guide me in the right direction.
I want to stay at the stock 1015cc because I had just adjusted the carbs sooooo puuurfect before she got frisky and scraped up the cylinder walls.
Any help would be appreciated, I couldn't let this bike go for some odd reason haha
Q1 - Between 1000cc and 1100cc models can you change the barrels and pistons straight over for the same model year?
Q2 - Can I put stock police bike barrels from the newer KZ's or older KZ's. Im looking for a straight swap
1980 KZ 1045 LTD Currently Workin' It Out
- bluezbike
- Thank you received: 104
79 KZ 1000 LTD
- APE Jay
- Banned
- Thank you received: 58
The J model and 1100 stuff will not bolt to your engine.
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- zed1015
- Thank you received: 1554
That means all 903 and 1015cc blocks.
Basically anything from a Z1/Z900 up to 1000A, Z1R, MK2 and ST1000.
As long as it's from a kicker engine it will fit.
- peavylotus
- Movin on up
Thanks for the info 'zed1015' thats exactly what I was looking for.
Also I am sending you a PM on whether you have a good set 'bluzbike'.
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Powerstroke_fan
peavylotus wrote: I definately need new pistons, they are scraped badly and the cylinders have to be bored up to use them again. Staying true to 1015 means I save money and time adjusting my carbs.
I wouldnt worry about adjusting the carbs. Thats just a fact of life. Its something you need to get used to doing. And usally from my past experince. When you take the carbs off and move them around and do motor work. I.e. change parts as pistons and rings some carb adjustment will be required anyway.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- peavylotus
- Movin on up
I talked to a guy with a CB café and he told me about a machinist who does side work for a fair price so the option of boring up is in my reach.
I am in the market for pistons, I want a full rebuild on this motor!
- Thank you received: 2064
For a set of MTC 1075 pistons , fitted to fresh bore job and rings setup for you to drop in Joe cant be beat for price and quality. I trusted him with my piston work and have been very pleased. Carbs will be a minor job to adjust
Have fun no matter what path you choose
- peavylotus
- Movin on up
