Replacing Head Gasket noob question KZ400
  • ejether
  • ejether's Avatar Topic Author
20 May 2013 17:12
#588389
I've got a 1974 KZ400 with ~5k on the clock.
Oil was leaking from the head-gasket so I've pulled the head and the cylinders.
Should I hone the cylinders when I reassemble? Will that require new rings?
The last time I replace a head gasket/base gasket on a thumper, I did nothing of the sort but I'm pretty new at the inside of engines..
Thanks for any insight.
  • Del_Herring
  • Del_Herring's Avatar
Re: Replacing Head Gasket noob question KZ400
20 May 2013 17:49
#588397
at 5k, I wouldn't think honing cylinders would be necessary unless something bad had hapenned to the engine. You might have been able to get away with just re-torquing them, but since you have it off now, definitely replace the gasket.
Mine's at about 35k, and I'm still using original pistons and rings. I look at honing more when doing a full rebuild, not just a gasket swap.
1983 KZ750-N2 Spectre
  • ejether
20 May 2013 17:52
#588398
Del_Herring wrote: at 5k, I wouldn't think honing cylinders would be necessary unless something bad had hapenned to the engine. You might have been able to get away with just re-torquing them, but since you have it off now, definitely replace the gasket.
Thanks for the input! Nothing wrong with the rings cylinders that I can tell. They might be a little glazed...
I would have tried re-tourquing but I also twised the head of all 4 intake boot bolts so the head had to come off and go to a machine shop anyway. At this point, I regret pulling the jugs off an messing with the base gasket, but thats more a time-spent-scraping issue.
