750L3 starter clutch
- mbsween
20 May 2013 09:09 - 20 May 2013 09:13
Okay,
Most everything came of easy, except the clutch hub. This isn't a left handed nut is it? I can't budge it with a 2' breaker bar, so I'm thinking of going to the impact driver. Safe to do?
Attachment small-basket.jpg not found
Last edit: 20 May 2013 09:13 by mbsween.
- KZipper
Re: 750L3 starter clutch
20 May 2013 14:55 - 20 May 2013 14:59
Not left handed thread. You can use an impact wrench to remove it, but make sure to use a torque wrench to install, and make sure the washer goes on the right way, I just did the starter clutch on my 650which is identical if yours is a four cylinder.
'81 KZ650H1 CSR
Last edit: 20 May 2013 14:59 by KZipper.
- Jesper
20 May 2013 17:59
Just done the same to my L3, and it's not left-handed.
My impact driver could not do the job. I had to use a 2m long pipe to get enough torque on the nut.
- gengomerpyle
20 May 2013 18:13
i need to do the same thing someday on my 750R1 but i cant do it at my apt complex. i dont have the confidence in myself to do it. it seams difficult to me.
mbsween wrote: Okay,
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- mbsween
21 May 2013 00:59 - 21 May 2013 01:05
Thanks everyone
With a little help from a Dewalt 18 Volt impact,I was able to get the nut off. For the record, the impact diver didn't loosen the nut much, but enough that I could turn it with a 2' breaker bar.
After dropping the oil pump and removing the retainer clip on the gear on the secondary shaft I was able to "tap" the secondary shaft into the right side case. I still haven't taken it out yet, ran out of time. Is there any trick to this?
Kzipper, Do you need a press to put the assembly back together after taking it apart? Just wondering whats ahead of me. I've owned this bike since new in 83. I hate when it is down, even though my newer bikes are much more capable and easy to ride!
Attachment basket-off.jpg not found
Attachment shaftin.jpg not found
Last edit: 21 May 2013 01:05 by mbsween.
- KZipper
21 May 2013 22:21 - 21 May 2013 22:24
No press required, it will tap back in, just hold the starter clutch assembly from underneath and slide the shaft all the way out to the right, then you can pull the large gear out of the clutch, then disengage the starter clutch from the primary chain and it's out.
Here is a link the the pdf I used when I did mine (Thanks to onkelb at kz650.info)
Kz650,750 four starter clutch repair
Hope that helps.
Hope that helps.
'81 KZ650H1 CSR
Last edit: 21 May 2013 22:24 by KZipper.
The following user(s) said Thank You: mbsween
- KZipper
01 Jun 2013 01:13
Update?
Did you complete the job?
'81 KZ650H1 CSR
- mbsween
01 Jun 2013 15:51
Zipper,
Now yet, just got the replacement bearing, the one under the starter clutch. The needles fell out while I was taking it apart. I'll probably get to it tomorrow
Matt
Matt
- mbsween
03 Jun 2013 08:39
Almost there
All the guts are in, Oil pan and clutch are back. Just the shifter cover, shifter and exhaust to go. Should be done tonight
- mbsween
04 Jun 2013 00:18
Okay, She is done!
Starts like a champ, road it for about 1/2 mile, with no issues. One drop of oil off the pan after approx 4 hours, I figure maybe that was already there during assembly. I'll track it for a couple days.
Here's a short video of me starting it 3 times. It is nice to have a starter clutch that works and even better sound like it was new. Probably save the battery too
New Starter Clutch in Action
Note that I said "new starter" when I meant "new starter clutch"
04 Jun 2013 00:26
Sweet!! Nice job and nice bike! Ed
- Jrbrownie00
04 Jun 2013 08:43
Did you just rebuild or completely replace?
82' kz750 ltd.
