750L3 starter clutch
- mbsween
Most everything came of easy, except the clutch hub. This isn't a left handed nut is it? I can't budge it with a 2' breaker bar, so I'm thinking of going to the impact driver. Safe to do?
Attachment small-basket.jpg not found
- KZipper
- Thank you received: 3
'81 KZ650H1 CSR
- Jesper
My impact driver could not do the job. I had to use a 2m long pipe to get enough torque on the nut.
- gengomerpyle
- Thank you received: 17
mbsween wrote: Okay,
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- mbsween
With a little help from a Dewalt 18 Volt impact,I was able to get the nut off. For the record, the impact diver didn't loosen the nut much, but enough that I could turn it with a 2' breaker bar.
After dropping the oil pump and removing the retainer clip on the gear on the secondary shaft I was able to "tap" the secondary shaft into the right side case. I still haven't taken it out yet, ran out of time. Is there any trick to this?
Kzipper, Do you need a press to put the assembly back together after taking it apart? Just wondering whats ahead of me. I've owned this bike since new in 83. I hate when it is down, even though my newer bikes are much more capable and easy to ride!
Attachment basket-off.jpg not found
Attachment shaftin.jpg not found
- KZipper
Here is a link the the pdf I used when I did mine (Thanks to onkelb at kz650.info)
Kz650,750 four starter clutch repair
Hope that helps.
'81 KZ650H1 CSR
- KZipper
- mbsween
Now yet, just got the replacement bearing, the one under the starter clutch. The needles fell out while I was taking it apart. I'll probably get to it tomorrow
Matt
- mbsween
All the guts are in, Oil pan and clutch are back. Just the shifter cover, shifter and exhaust to go. Should be done tonight
- mbsween
Starts like a champ, road it for about 1/2 mile, with no issues. One drop of oil off the pan after approx 4 hours, I figure maybe that was already there during assembly. I'll track it for a couple days.
Here's a short video of me starting it 3 times. It is nice to have a starter clutch that works and even better sound like it was new. Probably save the battery too
New Starter Clutch in Action
Note that I said "new starter" when I meant "new starter clutch"
- Thank you received: 2829
- Jrbrownie00
- Thank you received: 9
82' kz750 ltd.
