Valve Shims
- grumpy56
Valve Shims
19 May 2013 23:34
Does anyone know if the valve shims on a J motor are hardened or treated in a manner that would cause an issue if I precision ground the thickness just a bit? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- The_Proletariat
- "Cocaine is a hell of a drug"
Re: Valve Shims
19 May 2013 23:38
They are hardened. Do not grind them.
1982 Kawasaki KZ550 LTD
- grumpy56
Re: Valve Shims
20 May 2013 09:31
Thank you Proletariat.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Jeff.Saunders
Re: Valve Shims
20 May 2013 10:10This is what happens when you remove the hard surface of a shim and put it in the wrong way up...
I pulled this one out of a bike I bought. The shim said 2.65mm on the back, read 2.50mm on the edge, but read under 2.00mm in the center. The cam lobe was toast - down over 1/10th of an inch...
www.z1enterprises.com
Z1 Ent on Facebook,
- grumpy56
Re: Valve Shims
20 May 2013 13:50
Thanks Jeff. Perfect reason to not do what I was thinking of doing!
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- mtkawboy
Re: Valve Shims
20 May 2013 19:28
Last parts bike I bought the PO tried just removing the shims. That didnt work out too well, ruined the cam, bent the valves etc. Fortunetly I parts on hand to fix it
