cooks battery?
- roysclockgun
TIA,
Steven
- bountyhunter
- Thank you received: 337
YES. I don't know what else could be doing it.roysclockgun wrote: I am using a "Battery Companion" for my 1982 KZ750E. New battery bought in Jan. 2013. I have twice needed to put water in the battery. Could this charger be cooking my battery?
- MFolks
- Thank you received: 540
- roysclockgun
- gengomerpyle
- Thank you received: 17
www.batterymart.com/p-battery-tender-jr-...7NpbcCFYFQ7AodSSsAAw
roysclockgun wrote: Is there a battery self tending trickle charger that I can hook up and leave to keep the battery up, without cooking the water off?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- RonKZ650
- Thank you received: 240
- JR
- Thank you received: 448
I see another thread here asking What Battery Tender ? but I have to admit was wondering Why Battery Tender ?
- roysclockgun
I have heard that a battery tender with 1.5amp rating is too high. The ones with .750amp rating are good to use regularly. Do you agree?
When I bought my new Triumph last year, the dealership strongly recommended always keeping it on a battery tender. Of course, they did sell them.
Steve Ashe
- bountyhunter
If you use a lead acid battery, it needs a battery tender or it will die an early death. It must be a properly designed unit that is temperature compensated and won't overcharge the battery. The max current rating can be 2A, that's not critical since it does not send that much through the battery continuously. In the "standby" mode only a very minute current flows.roysclockgun wrote: I appreciate all the responses. It seems that there are two schools, in terms of whether to use a battery tender, or not.
Steve Ashe
- roysclockgun
All that I really have in the way of test tools would be an Amp/Volt meter.
Best,
Steven
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- turboking
1985 GS 1150E
1983 GS 1100E
