- Thank you received: 9
Not Starting but turning over w/ video
- Jrbrownie00
16 May 2013 23:42 - 16 May 2013 23:50 #587825
by Jrbrownie00
I just got it to start over the past weekend and even took it out for a quick ride. The only thing i did different was go from a BP8ES to a B8ES (properly gaped). Any ideas?
82' kz750 ltd.
Not Starting but turning over w/ video was created by Jrbrownie00
82' kz750 ltd.
Last edit: 16 May 2013 23:50 by Jrbrownie00.
- Thank you received: 2098
17 May 2013 00:21 #587837
by Patton
Replied by Patton on topic Not Starting but turning over w/ video
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
- Jrbrownie00
17 May 2013 00:25 #587838
by Jrbrownie00
82' kz750 ltd.
Replied by Jrbrownie00 on topic Not Starting but turning over w/ video
Thanks Patton. I should have done that right away.
Anyway it's an 82 kz750 ltd.
82' kz750 ltd.
- Jrbrownie00
18 May 2013 16:19 #588088
by Jrbrownie00
82' kz750 ltd.
I figured it out, thanks for the help lol
82' kz750 ltd.
- undiablo
- Thank you received: 64
19 May 2013 13:29 #588185
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic Not Starting but turning over w/ video
what was the problem?
- Jrbrownie00
19 May 2013 15:47 #588195
by Jrbrownie00
My starter clutch is failing. I either have worn springs/rollers or rounded years and the clutch will only engage at certain positions. I should have realized it right away but sometimes th obvious solutions aren't the first ones that come to mind. Thanks to my knowledgeable biker buddies.
82' kz750 ltd.
undiablo wrote: what was the problem?
82' kz750 ltd.
- Goalieguy35
- JJ
29 May 2013 22:44 #589840
by Goalieguy35
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
Replied by Goalieguy35 on topic Not Starting but turning over w/ video
To change that starter clutch is a job and a half. The 750s/650s were not diesigned like the 900/1000s with the starter clutch under the magneto cover instead they flipped the starter around and burried the clutch in the bottom end. Its a lost cause if you ask me, sorry
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
- Thank you received: 2829
29 May 2013 23:29 #589857
by 650ed
Replied by 650ed on topic Not Starting but turning over w/ video
Lost cause? Why? The parts are still available and even though it not an easy job many folks have done it. It just takes time, the manual, and a few bucks. Ed
- Old Man Rock
- Thank you received: 225
30 May 2013 08:29 - 30 May 2013 08:31 #589886
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Not Starting but turning over w/ video
No shit, I'm w/Ed on this one... Weekend worth of work and she'll be like new....
While you have her out of the frame, time for new gasket and seal set including new head gasket she'll be good as new... May as well buff out some of those cases as well... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 30 May 2013 08:31 by Old Man Rock.
- Jrbrownie00
30 May 2013 09:52 #589902
by Jrbrownie00
82' kz750 ltd.
I'm still riding it.
I'll fix it next time I have a free weekend, I'm trying to get the damn thing to pull through the whole RPM range right now. Needs a carb tune I think.
82' kz750 ltd.
- Jrbrownie00
31 May 2013 08:10 #590062
by Jrbrownie00
82' kz750 ltd.
The friggin thing wont start again.... Same turning noise but when I go to start the bike it want's to move forward and wont turn.
82' kz750 ltd.
