What model wheels do I have?
  • Matteson
  • Matteson's Avatar Topic Author
15 May 2013 18:14
#587566
I am in need of a speedo gear housing and need to know what model these are because there are some differenences. www.kawasakimotorcycle.org/forum/vintage...completed-kz900.html
KZ 900-a4
  • Matteson
Re: What model wheels do I have?
15 May 2013 18:41
#587569
Notice the bolt pattern that holds the disc on the front wheel. I can't find that on any pictures anywhere.
KZ 900-a4
  • Matteson
15 May 2013 18:52
#587572
1300?
KZ 900-a4
  • Dr. Gamma
  • Dr. Gamma's Avatar
15 May 2013 19:01
#587575
If its a 19 inch front rim. It might be a Morris Industries mag off of a 1976 KZ900LTD. Its been a LONG time since I saw that wheel. I kinda remember long bolts going through both discs instead of disc mounting bolts on both sides of the rim.
Look for the little Morris elblem that was cast into the rim. It was a "M" with an "I" over it.
If ain't a Morris mag, I got no idea what it is then!!! Sorry.
1986 RG500G 2 stroke terror.
  • trianglelaguna
  • trianglelaguna's Avatar
15 May 2013 20:11
#587585
just going by the 19/16 rim combo ,then looking at the disks...i'd say you have rims off of a 79-80 ltd 1000....but what do i know
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
15 May 2013 20:20
#587586
Examine both side the wheels very carefully for the name or an emblem or some other clue cast into them. I have never seen wheels that did not have some kind of identification mark (although I haven't seen every wheel ever made), so if you find anything cast into the wheel show a picture of it. Ed
  • Matteson
18 May 2013 00:26
#588009
So here are the pics of my wheels and speedo housing thats broke
and the one I bought off a 1000 doesn't look like it will fit even though the axle is the same size. If I knew the wheel model I would just get one for that. The wheel says 19x mt 1.85 Thanks
KZ 900-a4
  • Matteson
18 May 2013 00:29
#588010
Sorry first pic is the new speedo gear housing. Second is my bikes speedo. Looks different.Will the 1000 speedo work? I would really like to identify and then get the correct model speedo gear housing instead of guessing.
KZ 900-a4
  • martin_csr
  • martin_csr's Avatar
18 May 2013 09:19 - 18 May 2013 09:22
#588040
You may be right about it being from a 1300. From looking at a few 1000 models & the 1300s, the 1300 is the only one I saw having a disk of that type w 7 bolt holes. All the others I've seen w that type of disk have 4 holes. To check further you could zip around the diagrams at Partzilla. The Kawasaki.com site takes more work.
Last edit: 18 May 2013 09:22 by martin_csr.
  • Matteson
18 May 2013 10:48
#588058
No eBay APP ID and/or Cert ID defined in Kunena configuration I think that looks like what I have.
KZ 900-a4
