KZ1000 Clutch Issue / Big problem
  • KZ1000 Hardtail
  • KZ1000 Hardtail's Avatar Topic Author
15 May 2013 18:09
#587564
Hello,
I need some help on my bike and I hope to find the answer here. I have a 1996 KZ1000p with 56,000 miles on it. After building it I found the clutches slipped at a higher RPM but grabbed well at low. So I purchased an EBC Kevlar clutch rebuild kit. I have a manual and it wasn't a hard job. After replacing the clutches I followed the adjustment as it stated. loosen mid cable adjustment and loosen handle. The engine adjuster stated to turn to counter clockwise till its hard then back 1/4 turn. My adjuster is all the way out and still hard. so i put back together and clutch didn't work.
I came to the conclusion to take the threaded adjuster out of the cover and try that. Bam!! it works, but still slips on hi-way. I don't want to run with out the adjuster in it. What did I screw up or ? Any help would be great!! Also couldn't find the torque spec for the clutch spring bolts so i went with feel on that lol
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: KZ1000 Clutch Issue / Big problem
15 May 2013 21:50
#587604
I would get the torque spec on the clutch spring bolts. Also if you didnt already replace the springs with some heavier ones.
1977 KZ 1000 work in progress
  • APE Jay
  • APE Jay's Avatar
15 May 2013 21:51
#587605
Why did you buy the EBC clutch? Because it was a great ebay deal?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
15 May 2013 21:54
#587607
What kind of oil you running ?? New auto oils would make for a slipping clutch vs motorcycle oils for a wet clutch system.. Just a thought to check this before going crazy
Dave B) B) B)
15 May 2013 23:30
#587644
KZ1000 Hardtail wrote: ...The engine adjuster stated to turn to counter clockwise till its hard then back 1/4 turn....
Some manuals are reportedly incorrect.
Would also try clockwise until stops, then counter-clockwise 1/4 turn.
May not help, but won't hurt to try.
Good Fortune! :)
  • Old Man Rock
  • Old Man Rock's Avatar
16 May 2013 08:17
#587694
" turn to counter clockwise till its hard"....
Hard being the key word.... Found in my KZ900 doing this resulted in a No Go...
Turn until you feel it just barely make contact then follow the rest of the procedure...
Worked as expected for me, may for you as well...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
