crossover pipe fit
- canroc
crossover pipe fit
12 May 2013 22:17
The crossover pipe is cracked on my '80 KZ750. I see one on ebay for a late 70's KZ650B. Does anyone know if that would fit the 750?
Thanks.
Thanks.
Re: crossover pipe fit
12 May 2013 22:23
Yes, according to the cross-ref for the 750E at Partzilla. You could double check the x-ref at Kawasaki.com.
12 May 2013 23:47
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
The link is also provided in my signature.
For example, muffler connector pipe part no. 32032-1669 is used on the following 23 models:
KZ305-A1 (CSR) (1981)
KZ305-A2 (CSR) (1982)
KZ305-B1 (CSR Belt) (1982)
KZ305-B2 (LTD) (1987)
KZ305-B3 (LTD) (1988)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
- canroc
13 May 2013 08:56 - 13 May 2013 08:57
Related. If the connections at the pipes are in poor condition or shot, someone here on KZR used copper plumbing fittings to make a repair.
Last edit: 13 May 2013 08:57 by martin_csr.
13 May 2013 11:04Perhaps this thread:martin_csr wrote: Related. If the connections at the pipes are in poor condition or shot, someone here on KZR used copper plumbing fittings to make a repair.
www.kzrider.com/forum/2-engine/432214-81...-nipple-broke#432478
13 May 2013 12:18
Yes, that is the exact topic, pictures n all. Thanks.
