Gearchange shaft and clutch pushrod oil seal z1100
- Davereplicant
12 May 2013 21:12
Hi, as well as a weep from the grommet on the alternator cover where the cable goes through the grommet I think I may also have a leak from the two areas mentioned above.
I've read elsewhere on the forum the gear change shaft seal is a simple job but the clutch rod seal is a split the crank job on some bikes.
I'm working on a kz 1100 a-3
Would anyone be able to she'd some light on this and any tips?
Thanks in advance
Thanks in advance
- Motor Head
Re: Gearchange shaft and clutch pushrod oil seal z1100
12 May 2013 23:22 - 12 May 2013 23:27
Kawasaki.com will have the parts fiche for you to look at an exploded view. Its the J engine 1100, all the seals are on the transmission cover, under the sprocket cover and sprocket. Replace all of them at the same time.
www.kawasaki.com/DefaultFrame.aspx?strCo...d1983%26SHOWVEHTABS%
Also the service manual link in my signature will have the procedure.
Last edit: 12 May 2013 23:27 by Motor Head.
The following user(s) said Thank You: Davereplicant
