Trying to figure out if cases have been ground
- RobK
11 May 2013 03:46
More on this lot of machines I bought.
Anyone know the standard bore of the 900s/1000s?
The fours sets of Z1/KZ900 cases I measured were ~76mm to 78mm front to back. Guessing stock?
I've got a set of 1000 cases and the bores in upper case look effing huge, ~89mm front to back. :ohmy:
The PO was heavy into drag racing, so anything is possible.
Got 3 sets of cylinder blocks that are standard - 66mm, and one that is 74mm (KZ1000 block). Also have 3 pistons that came with everything - 80mm - big suckers.
Thanks
Thanks
My mule's got the funny idea you're laughin' at him. Now if you apologize like I know you're gonna...
- Powerstroke_fan
Re: Trying to figure out if cases have been ground
11 May 2013 17:42
What brand of pistons are the three 80mms you have. How about the compression.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- APE Jay
11 May 2013 20:51 - 11 May 2013 20:52
The machining in the cases from the factory usually look like it has been painted. Aftermarket bore job looks like raw machined aluminum
Last edit: 11 May 2013 20:52 by APE Jay.
- RobK
12 May 2013 16:09 - 12 May 2013 16:13
No markings on the pistons. Crowns look shallow to me. No even sure they are z/kz.
Attachment 2013-05-1212.45.29.jpg not found
Attachment 2013-05-1212.45.48.jpg not found
Last edit: 12 May 2013 16:13 by RobK.
- RobK
12 May 2013 16:11 - 12 May 2013 16:15APE Jay wrote: The machining in the cases from the factory usually look like it has been painted. Aftermarket bore job looks like raw machined aluminum
The 900s cases all look like they have paint, the ports are not pefectly round, and have a slope to the side of the wall of the opening - assuming stock.
The KZ1000 head on the other hand, have big round holes with what looks like maching marks.
Pics below..
Attachment 2013-05-1212.48.57.jpg not found
Attachment 2013-05-1212.50.31.jpg not found
Last edit: 12 May 2013 16:15 by RobK. Reason: typos
- Dr. Gamma
12 May 2013 16:42RobK wrote: No markings on the pistons. Crowns look shallow to me. No even sure they are z/kz.
They look like early MTC pistons.
1986 RG500G 2 stroke terror.
13 May 2013 11:28 - 13 May 2013 11:30
you should always measure pistons on the skirt 90 degrees from the wrist pin,because they are oval and tapered and the skirt is the largest area.
those cases you showed have been bored out for sure.
Last edit: 13 May 2013 11:30 by 531blackbanshee.
- RobK
13 May 2013 15:02Thanks very much - good to know! I'm guessing that case was bored out for a pretty meaty increase in displacement as I know you can go up significantly without touching the cases.
That makes me think I'm gonna sell those as I understand that going that far up (with an air-cooled engine), means a much higher maintenance motor, (eg. not a daily rider).
- APE Jay
13 May 2013 19:49
Those cases are bored. We may have done them. Is there a number engrasved on the bottom of the motor mount area?
Those pistons are old MTCs.
- RobK
13 May 2013 20:00APE Jay wrote: Those cases are bored. We may have done them. Is there a number engrasved on the bottom of the motor mount area?
Thanks.
Couldn't find any numbers engraved except the SN, oil capacity, and case bolt numbers. These cases have been in a garage for at least 13 years. Have you always marked your cases?
