1981 KZ1100A Shaft w/ Vetter Fairing Exhaust Fit
- dom
10 May 2013 22:03 #586797
by dom
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
1981 KZ1100A Shaft w/ Vetter Fairing Exhaust Fit was created by dom
Hi.
I just picked up this rig:
I'm looking for a 4 into 1 complete exhaust in all chrome to fit.
Getting around the bags seems to be an issue.
Figured someone here might have some suggestions.
I want to be able to get to the filter, drain plug, and retain the center stand.
More pictures here:
1981 Kawasaki KZ1100A Shaft
Thanks!
-dom
More pictures here:
Thanks!
-dom
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
- havakaw
- Thank you received: 27
12 May 2013 09:00 #586979
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic 1981 KZ1100A Shaft w/ Vetter Fairing Exhaust Fit
Keep the head pipes and just replace the mufflers with some shorter turnouts.
'80 KZ 750 LTD-H
- dom
12 May 2013 10:28 #586992
by dom
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
Replied by dom on topic 1981 KZ1100A Shaft w/ Vetter Fairing Exhaust Fit
Doh, I'm hoping to get a tuned header on there too.
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
- TomW
- Keep the blue side up.
- Thank you received: 52
16 May 2013 17:24 - 16 May 2013 17:25 #587786
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic 1981 KZ1100A Shaft w/ Vetter Fairing Exhaust Fit
I've got a '78 LTD with the same bags. By reworking the bag bracket I could raise them at least 3". You should be able to do the same. Or put a Mac 4 into 2 turnout exhaust on it.dom wrote: Doh, I'm hoping to get a tuned header on there too.
Last edit: 16 May 2013 17:25 by TomW.
- daveo
- Thank you received: 655
17 May 2013 03:42 #587858
by daveo
dom
This is how a V&H 13009-J mounted to my bike. V&H said it wouldn't work, but I had to try it anyway.
Had a couple issues, but it does mount to the head correctly.
1982 KZ1100-A2
Replied by daveo on topic 1981 KZ1100A Shaft w/ Vetter Fairing Exhaust Fit
dom
1982 KZ1100-A2
- dom
27 May 2013 11:48 - 27 May 2013 11:53 #589395
by dom
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
Thanks for the replies guys!
I ended up ordering a Mac 4 into 1 Canister system.
Just lining it up seems like it's a neat fit.
All access points are kept as well as the center stand.
Was not able to get the header in chrome so I sent it of to get it ceramic coated.
The canister is chrome though.
Once I get it on I'll post a picture.
Next step is a to check the valves and order some shims if necessary.
Then get some new bearings in the steering.
Shoot, I need to get some air filter pods too and think about jetting this unit.
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
Last edit: 27 May 2013 11:53 by dom.
- dom
02 Jun 2013 17:18 - 02 Jun 2013 17:19 #590481
by dom
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
-dom
epautos.com
'81 KZ1100 A1 Shaft
'85 Honda 350x
'96 HD EG
Last edit: 02 Jun 2013 17:19 by dom.
- daveo
02 Jun 2013 20:40 #590522
by daveo
1982 KZ1100-A2
Please post installed pics when completed .
I am very interested to know how well this Mac header system integrates with the center-stand, and how accessible the oil filter is, once you have it installed.
The V&H 13009-J (for KZ1000-J) came with a metal bracket (for the left side) to serve as a stow-stop for the center-stand, since the muffler is not there to catch it. It works well (after shortening about an inch), considering the design application was not intended for the 1100-A to begin with. The V&H tech was helpful though, when stating there was no possibility the header would work on my bike.
1982 KZ1100-A2
