Timing off 180 degrees?
  • nivlac
  • nivlac's Avatar Topic Author
09 May 2013 22:31
#586648
Trying to start my kz1100 after top end rebuild. I'm getting a lot of backfiring. I'm thinking it may be out of time. I went through all the required positioning of my valve train and timing chain. Number 4 lobes facing one another, Exhaust arrows pointing forward, Intake to the rear, 44 pins end to end as well as the notches on the right side of the cam in position. With the positioning that is done can the timing be 180 degrees off?
1983 kz1100
1979 cb650
  • Motor Head
  • Motor Head's Avatar
Re: Timing off 180 degrees?
09 May 2013 22:38
#586650
If you had the 1-4 "T" mark lined up, then no. But you could have the wiring off. The coil wiring could be swapped around. So then 1-4 is firing when 2-3 should be. Not to hard to see, just swap the primary wires to the other coil.
  • nivlac
09 May 2013 23:08
#586655
What do you mean the primary wires? Are we talking about the small wires that plug into the coils or the plug wires?
1983 kz1100
1979 cb650
  • Motor Head
09 May 2013 23:12
#586656
Small wires. Plug wires are probably set closer to length, so they won't swap out to easy.
have you checked compression? You can turn the motor by hand and see when #1 has compression. Then rotate to the 1-4 "T" mark it shouldn't be far away.
  • nivlac
09 May 2013 23:22
#586658
There is no way to know if we are at #1 compression or at exhaust w/o taking off the cam cover to see valve location is there? I mean I will if I need to but don't want to if I don't have to.
1983 kz1100
1979 cb650
  • Motor Head
09 May 2013 23:25 - 09 May 2013 23:27
#586659
Sure its easy. Take off your Ignition cover, use the 17mm head nut to turn the motor in direction of normal rotation. With the #1 plug out, you will hear the air pressure escaping. You could hold a finger over the plug hole and feel the pressure building. Unless you are off on cam timing or valve adjustment, you should have compression here. Line up the 1-4 "T" mark when you feel the compression on the #1 plug hole. That will be #1 TDC.
When you get it lined up, look at your Ignition, the Rotor lines up with the Pick-up coil. Should line up with the rear one, towards the back of the bike, or left side as you look at it.
Last edit: 09 May 2013 23:27 by Motor Head.
  • nivlac
09 May 2013 23:49
#586664
Thank you my friend. So if my timing is good, switch the wires on the coils? Do the wires have +/- polarity? Been worrying about this all day. Now I can worry about other stuff.
1983 kz1100
1979 cb650
  • Motor Head
09 May 2013 23:52 - 10 May 2013 00:01
#586665
No the coils don't have a polarity. Although some are marked + and -, many are not.
Did you look to see where you ignition rotor was pointing when on #1 TDC?
On your Ignition coils, the Red and the Black wires should be on the coil you have the 1&4 plug leads on. Green and Red are for the 2&3 coil. Look at you Ignition Rotor, it should be facing back towards the rear which is the 1-4 pic up coil.
The service manual link in my signature has all of this info and lots more.
Last edit: 10 May 2013 00:01 by Motor Head.
  • nivlac
10 May 2013 00:00
#586667
No I gotta turn in I'll check after work tomorrow. Thanks
1983 kz1100
1979 cb650
  • nivlac
10 May 2013 08:03
#586686
Couldn't sleep ........ much. Woke up at 5:00, checked my timing which was good, switched the coil leads and VROOOM.
1983 kz1100
1979 cb650
  • Motor Head
10 May 2013 09:47
#586693
Sweet. Hopefully you can go ride now.
B)
  • loudhvx
  • loudhvx's Avatar
10 May 2013 10:35
#586706
It won't affect the way it runs, but you may want to confirm everything is set up like it was from the factory for easier troubleshooting later.
For the large inline 4 motors:
Ignition rotor points backward (towards the pickup with black and blue wires) when 1&4 are at TDC.
The left coil is for spark plugs 1&4, and gets the black wire.
The right coil is for spark plugs 2&3 and gets the green wire.
